Don_Miller2@hotmail.com
- 0
- 0
- Portland Oregon
Harbor Freight has a 24 volt Diesel transfer pump for abount one hundred dollars.
It must be hard to walk with balls that big.![]()
WM:It must be hard to walk with balls that big.![]()
Several thoughts come to mind....Its not hard at all![]()
1. Talk to your wife/partner about THAT !
2. Consult your doctor/urologist.
3. You should consider long exposures to temperatures below 32F/0C for that "hard as ice" affect.
4. Little Blue Pill - V I A G R A
5. Have you considered the Priesthood? A vow of celebacy?
6. Try his job WITHOUT the Faraday Suit and see if that helps
7. Maybe, just MAYBE you meant to type.... "It's not DIFFICULT at all." .... that would have saved me a whole buncha typin'![]()
You guys are making the apocalypse too difficult. Forget about the Deuce.
Just go back to steam-powered cars. Burn wood, coal, garbage, whale blubber, zombie limbs, whatever.
Sure it's smaller and slower. But unless the sun goes out it'll always have fuel. Wood vapors work as well when adapted to regular engines.
Wood Car - Part 3 on Vimeo
Beaver Energy Wood Burning Car on Vimeo
Stanley Vanderbilt Racer at the 2009 Newport Hill Climb. on Vimeo
Rolly Evans seen running his Stanley EX on Vimeo
Steam Car Club videos
I have long been an admirer of STEAM POWER, but have always relegated its application to Locomotives rather than Automobiles and Trucks simply because of the marginal efficiency factor and its exponential improvement as scale increases.You guys are making the apocalypse too difficult. Forget about the Deuce.
Does an intimate knowledge of some good Mexican Bean recipes count in order to "cobble together a gassification system"If you had access to a stockpile of coal and the mechanical and chemical knowledge you might be able to cobble together a gassification system.
I'd be real carefull using a drill near a gas tank, most are open brush. I see them and sparks on my 18v black and decker... I also agree that you shouldn't damage a vehicle unless you have to be quick, or there are plenty. You never know when you might need it or a part off it.A lot of them are plastic and can be opened easily with a cordless drill with a big bit.
Go ahead Richard, give away all the secrets of how I'm getting around when SHTF. Why do you think I own MV railcars? Hmmm???? lol.Another thought that came to my mind is rail cars full of veggie and other flammables....Archer Daniel Midland ships whole trains of tanker cars full of veggie oil. That much oil would last a long time and could be used for other uses than fuel since it is food grade oil.
This would depend on where you found it and if you could maintain control of it.
If the grid goes down I'm not sure what would happen to the railroads.....do modern diesel engines have computer control? I know there is an elaborate ground trraffic control system for trains to keep track of them and that knocking out communications would disrupt that. There may be trains stranded out in the boonies just waiting to be scavenged.
It is amazing how tied together all these systems are. One domino falls and takes the rest with it.
did you get the self priming pump or then non self priming pump.?Hey Coldwarrior,
I Think Josh was right on target. In the scenario you spoke of, you will not be wanting to be standing around waiting for fuel to load into you truck in slow motion. You will want to get it and back out drawing as little attention as you can. The military Fuel Transfer Pumps are just the ticket. They plug right into the side of your Deuce (24 volt) and will fill you up right now (35 GPM). They will pull fuel up from an under ground tank no sweet. They are light weight and easy to transport and handle. You will have to keep an eye out on GL, but they are there, and they are worth the effort. Picked five up from Ft. Carson some time back, four had not ever been used. The cost was around the three hundred dollar range. Each of my friends now have one in their Deuce for any needed calling. GOOD INVESTMENT. I believe in having fuel, I can carry up to 180 Gal in the Deuce and up to 50 Gal more in the trailer. With no fuel, all you have is a cool looking ornament.
