Hey guys I just found an issue and dollars to donuts it is the same
on every one of these trailers
and it really needs to be addressed IMO.
I pulled a brake caliper to see just how bad the rust is and the 2 brake caliper
slider shoulder bolts are jacked. Those things should be chrome plated, very
smooth, lubed and easy for the caliper to float upon. This means
the pads AND expensive rotors will wear wrong, and not work
as they are supposed to. These bolts are supposed to be greased
w/ a high temp caliper grease AND, all the O-rings feel hard too.
NO BUENO AMIGOS!.
Shoulder Bolts need to be replaced.
The install tool will make it easy,
New O-rings for all replace them all. 40 of them (Yes 40 )
The anti rattle springs are rusty, mind as well get anew.
I will clean the rust off the pads and rotors w/ a conditioning pad and reassemble
and while in storage cover the tops to keep off rain.
I glassbead blasted the rust off the PADS and gave
them a quick shopt of BBQ black paint to keep corrosion at bay.
I have a call into a trailer place getting a price for the parts. I think it will be
about $140 dollars or so. If you wait I might have a phone number
for you to call and this gal will already know what's up.
So it looks like a pretty easy job and only $35-$45 a wheel, so it's
a no brainer in my book.
1- Installation Tool for Shoulder Screws P/N 071-182-00 (Get this so you don't jack the O-rings! Lube it!)
4- Shoulder Screw 5⁄8 x 5 TOTAL 8 BOLTS P/N 007-186-00
4- "O" Ring TOTAL 40 RINGS P/N 010-062-00
4- Anti-Rattle Spring TOTAL 8 SPRINGS P/N 046-105-00
1- CALIPER GREASE
![caliper-bolts.jpg caliper-bolts.jpg](https://www.steelsoldiers.com/data/attachments/351/351967-232a972157a8b5bf8ff6de2f544e4c88.jpg)
