servicing deuce injectors
winfred
10
port allen la
smells like liquid cancer and works great on small engine carb's and is my go to for that, melts the crap off that even good carb cleaner doesn't get, haven't extensively used it on engine parts but it basically smells like just about any old machine/head and block shop and is likely related to the pro stuff
anybody use/try this stuff?
Beeryman Chem dip
Beyond Biodiesel
37
Prescott, AZ
... or save time and buy new ones, here...
I ordered a set of 6 injectors from TaylorTradingCo, as reported upthread. They arrived promptly, in good condition, and properly packed for shipment in their original boxes. I installed them in my 1969 M756A2 and found they did not solve the cold starting problem of my multifuel engine. So, about 2 weeks ago I pulled them and pop tested them. I found them on spec. At that time I also found that they had the scew-type pop pressure adjustment, which was good. So, I put them back in, and will look for other causes of my multifuel engine's cold starting problem.
Also, I ordered the adapter for the multifuel injectors available from Tubes and Hoses in Colorado. The adapter was inexpensive, and arrived promptly. Thanks to Menaces Nemesis.
rustystud
3,389
Woodinville, Washington
I ordered a set of 6 injectors from gringeltaube, as reported upthread. They arrived promptly, in good condition, and properly packed for shipment in their original boxes. I installed them in my 1969 M756A2 and found they did not solve the cold starting problem of my multifuel engine. So, about 2 weeks ago I pulled them and pop tested them. I found them on spec. At that time I also found that they had the scew-type pop pressure adjustment, which was good. So, I put them back in, and will look for other causes of my multifuel engine's cold starting problem.
Could be the injection pump. It needs to be adjusted (externally) periodically.
