Yup. Use Permatex to reseal. Make a new gasket from sheet gasket material from your auto parts. If you ruin the existing gasket.I will need to re seal that circular piece correct?
Thanks, will dig into this tomorrow. Can I use the same dot 3/8 air line for whatever is inside this assembly?Yup. Use Permatex to reseal. Make a new gasket from sheet gasket material from your auto parts. If you ruin the existing gasket.
No the hose must be diesel fuel rated hose.Thanks, will dig into this tomorrow. Can I use the same dot 3/8 air line for whatever is inside this assembly?
