Mos68x
- 36
- 28
- Seligman,AZ
Haven't got the EGT gauge yet, I'm getting that in a couple days, which is fine since the truck will stay parked until then anyways.
Cool, always want to compare what others are seeing...Haven't got the EGT gauge yet, I'm getting that in a couple days, which is fine since the truck will stay parked until then anyways.
lol!!!!!!if you like your pump, you can keep your pump.![]()
Where do I get the 3k governor springs?cool site!
Yeah, the 8.3 shares nearly the same pump as a 5.9. Not all do, and that's where you need to look. Make sure it's a P-pump, and not the electronic junk.
Mods are simple. Grind down the fuel plate flat, and install it full forward. Hike up the timing to around 17-19*, and buy a set of 3k gov springs($100). Depending on the pump it has, you can see up to around 360hp, which is a grunt of tork at around 1100 pounds.
I called a place. I think it was test or something like that and they said they didn't make springs for the 8.3. What specifically to look for. Also I'd like to talk to u about all the motor mods if u ever get a minute to talk. Thank u very much for your timeEbay is the easiest. Just type in "dodge gov spring kit" in a search.
Are 4k springs too much?PacBrake p/n HP10029. Available everywhere.
