EVANSWASTEOFMONEY
- 14
- 3
- BOSTON,MA
I found it just google this partContact Tom Cepek regarding CTIS and CTIS delete
Wow that is allot of $$$I don't have an actual truck yet.
Mines blocked up in EUC
but i am moving right along
new custom 24 volt alternator. i will run both a 12 and 24 volt system. Looking into batteries next
I spoke to them and if anyone wants a 24 volt alternative for a lsx swap they can use this link
https://www.tucsonalternator.com/pr...nator,-Durable-6-Phase-Hairpin-Technology/H-/ They just listed this part.
I'm not sure what trans/transfer he is going to use but I have been beating on a 7/10K drive train (diffs/axles) 2.56 gears with over 400HP and well over 700ftlb of torque without being able to break anything, just turned 17K on the conversionHave to ask the obvious question,
is the transmission, transfer case, driveshafts, differentials and axles going
to be Upgraded (a lot?) to be able to harness this power?
no idea on gears ect. it's a 2001 and hasne't been shipped yet.I'm not sure what trans/transfer he is going to use but I have been beating on a 7/10K drive train (diffs/axles) 2.56 gears with over 400HP and well over 700ftlb of torque without being able to break anything, just turned 17K on the conversion
I am assuming he is starting with a 12k truck with 2.73 gears which that LSX should be pretty happy with depending on the final transmission ratio.
That thing should be a blast!!! Just remember any time you bust the rears loose it will try to swap ends!!
