- 7,391
- 2,438
- 113
- Interlachen Fl.
C and D code pumps do not have a droop screw. If no droop then smoke cam is set to specs for that IP.Is there not a 1/8th allen adjuster in that small hole???? I saw some info just last week where they were talking about which IP's had smoke screws and which ones you had to adjust the angle on the cam in the IP. Now just to find it again........
PS just rember a little turn goes a long way on the droop screw and same on smoke cam. When disableing FDC with no droop then it would not take much of a angel change to affect the 1600 to 2000 rpm fuel.
