dm22630
- 42
- 0
- Front Royal, VA 22630
About the winching, how much cable was on the drum when the pin snapped?
With a lot of cable on the drum, the shear pin will snap way before the max rated pull has been reached. From what I have learned (see related thread from last week), I would have started winching 200 ft away to get the max out of it, perhaps you did, it's not clear....
I broke the shear pin after I had already winched myself out. What happened was, I had 10-15 ft of cable still laying on the ground, so I wrapped it around the bumper so I could turn around & then unspool it again & winch the 818 out. I got in the truck, put the winch in neutral & pulled forward. I heard a LOUD "pop". I got out & the cable was extremely tight around the bumper & I could see the pto spinning. I never pushed the clutch lever on the winch back before I moved, so I guess it didnt disengage anything.
I hope it is just a shear pin.
