V100 mods
wgtactical
435
Carrollton, Georgia
Subscribed. Maybe even a little over the top, but... a Happenin' thread!
Thank you:-D
Awesome rig I can only dream
That's the first step:wink:
Here's the transfer case we are rebuilding/upgrading for this machine. We'll be replacing the ball bearings with roller bearings that can be properly pre-loaded. Also adding a pump that will be driven from the first idler shaft (which is also the slowest turning of the two idler shafts) that will deliver a steady oil flow to the top set of bearings as well as pushing the oil through the oil cooler. The flanged bearing adapters along with the yellow zinc plated caps are just a few of the new fabrications necessary for this upgrade.
B3.3T
109
SW Ohio
Indeed, hard to find for sure. We paid $12K for a transfer case years ago from Jamaica and were glad to pay that. Luckily they are overbuilt.
Another Ahab
4,967
Alexandria, VA
You clearly know what you're doing. VERY impressive.
wgtactical
435
Carrollton, Georgia
Thanks for the kind words!
We've been able to reverse engineer the entire case and are considering building our own at some point but our gearcase will be fully machined and we'll probably have a couple different ratio options to choose from as well.
Another Ahab
4,967
Alexandria, VA
If you all ever open a satellite shop up here in the Mid-Atlantic area, please broadcast the news.
I'd go to it for any kind of custom work ever needed, in a heartbeat.
Rickv100
NJ
WG,
Did the Guatemalan Armadillo play a part in your designs? It looks very similar
Supposedly the Guatemalans built their own transfer cases in the 1980's.
Rick
wgtactical
435
Carrollton, Georgia
WG,
Rick
That is the first time I've seen that machine and it certainly looks interesting. However, my inspiration for the Cummins conversion came via a gentleman that goes by the screen name of trades2much on here. He had repowered a LAV150 for Linn county SWAT in Oregon and I was so impressed with his project that I picked up a Cummins commonrail and a Allison 1000 for my own. Additionally a lot of imagination and 3-D computer aided design made the curb appeal and creature comforts come to life.
Rickv100
NJ
Photo from the front of the Armadillo. TNJ Murray(or its predecessor) was shipping axles to them in the 90's for the Armadillo.
Rick
Rickv100
NJ
The Armadillo's are another offshoot of the V100 family tree. Chiamite, Dragoon ASV300, Armadillo are all similar.
Rick
Another Ahab
4,967
Alexandria, VA
Wonder what that hardware is off the roof of the vehicle?
And I'm guessing that's a davit crane of some kind at the rear…anybody know? Rickv100?
M813rc
3,955
Near Austin, Texas
The T-looking things are the open gunner's-hatch doors. Each side of the hatch door has a vertical plate attached: when opened, the vertical piece hits the edge of the ring and holds the hatch door at roughly a 45 degree angle. Makes a decent little bullet trap to protect the gunners sides. Somewhat.
Hopefully the attached pictures will clarify my description.
Cheers
Another Ahab
4,967
Alexandria, VA
Cheers
I hear you: "Guarantee by the Manufacturer is Expressly Limited"!
My thanks to all for the clarifications. The Armadillo looks like a real tight little piece of rolling iron.
M813rc
3,955
Near Austin, Texas
The Armadillo is indeed a cool looking vehicle. It came about when the US refused to supply them with any more V100s because of some perceived annoyance, so they built their own version.
The attached picture shows the hatch closed, you can see the attached almost-vertical piece.
Also one with the guns on.
Cheers
