WARWAG
- 24
- 38
Heres a pic of the oil I used.
If the truck still shifts hard after checking the vacuum lines PM doghead he has NOS regulator valves I bought two of them it will shift like a new truck.
You may have already found out which engine you have. Two things you can ck. First, look at front of engine RH side (pass side) right below where the head & block come together. If it is the std. 6.2 it will have it embossed on a flat area of the block "6.2 d". If it is blank, it probably a 6.5. The other ck , see if you can look at the side of your IP (injector pump) on the LH side to ck the mod # of the Stanadyne pump. All 6.2 used a no. system like DB2829-xxxx (4 #s). The 6.5 used diff. pump & they started with DB2831-xxxx. They may have just banged up the oil pan & just replaced it with the newer 6.5 pan. If it is a DB2831 IP pump, they would have had to do some mods on inside of pump to make it 12V. Main ck is the first thing I mentioned.
