gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
Menace, ive found it easier to pull the topp off the trans when dropping/raising. Make sure you shift it so the peg isnt sticking out the back first. Also its good to see others using a clutch with out springs. Big trucks dont need em!
Menaces Nemesis
"Little Black Truck" Conservator
262
Denver, Colorado
Thanks for the input Gimpyrobb... I'm genuinely curious, what in particular have you found simplifies the job by removing the top plate before lowering the trans?
gimpyrobb
27,791
791
Cincy Ohio
The smaller size gives you more room to maneuver, also, I believe that rod is in the top part of the trans. I forgot about that till after I posted.
Menaces Nemesis
262
Denver, Colorado
Looks so much cooler than my ghetto tool made with a 1/2 inch ratchet extension, a deep socket and electrical tape to increase diameter.
That sounds like about exactly what I did to drill a 2" gauge hole in my dash where a 1" hole was... Used a socket as a pilot for the holesaw. A bit of resourcefulness makes a hobby like this so much more do-able.
tobyS
840
IN
You got a nice looking truck Mrmag1, with hard top and fold down sides. Good score!
gimpyrobb
27,791
791
Cincy Ohio
Got her home, pix and info to come, she almost killed me on the drive home in the TX heat.
Close all windows and vents, then open the windshield on the passenger side. The air flow will force all the radiant heat out of the gaps that it normally comes in from.
(I use the pass side only as the big bugs hurt when they hit your face at 50mph)
tobyS
840
IN
It's a really beautiful truck.
That nice white drive will let you know if you have any leaks.
Here's a suggestion for covering the grill cheap. Here is my 817 with a bit of Aluminum expanded metal on the grill.
SRB1976
9
Hanna, Wyoming
Installed a new bridge plate today. The old one was pretty ratty looking. What a pain in the butt to replace it with the grill attached to the truck:mad:
The old one
cattlerepairman
3,537
NORTH (Canada)
Wow..I would probably have cut out a newspaper cover, rattle-canned the bridge plate green and called it a day! The new one looks sharp, though!have
Mrmag1
Head of Stuff N' Things
14
Hereford Arizona
@sgms18
A Jones turbine muffler, I had it installed while I was deployed. It does make a difference, same awesome C turbo sound at far less decibels!
