SCM35A2
3,388
Florence, SC
Got a few things done today...air cleaner completely painted, turbo housing & exhaust manifold cleaned up & painted with high heat paint, removed the intake pipe & cleaned up the rust on it. Also got both rear splash guards primed up, will paint them & install tomorrow...
Privatewrench
19
Kentucky
Drained the steering box a couple days ago. Had the usual gear oil in it. Today I filled it with JD corn head grease.
This weekend I might finally get to removing the radiator so I can completly flush the system. I have new belts and coolant hoses to put on her. Been wanting to do that for awhile.
fpchief
229
South Alabama
I need to put corn head in my winch. Cant keep anything else in it.
fpchief
229
South Alabama
I installed the transfer case shifter boot. I tried to use the shifter boot that I’ve seen others use here (Mr. Gasket, I believe?) and it didn’t look like it was going to work without tearing when the transfer case was in low range. So I had to go an alternative route.
View attachment 786933View attachment 786934View attachment 786934View attachment 786933
Holy hell I like that one. I have the Mr Gasket one and it is ok but this one is cool. I can see it being a custom job.
Tracer
14,440
Hawthorne, NV.
Will see if they have it in the morning....gotta go there anyway!
10-4 I'm going to head on over to my NAPA shop in the morning. I don't need it for the Deuce but I got a friend with a 56 Studebaker Champion that has a steering box with a slow leak.
rustystud
3,392
Woodinville, Washington
Now that is real nice and very clean looking !!!
Did you make the plate yourself or did you have it made ? If you had it made, how much did they charge you and are they willing to make more ?
Ajax MD
1,437
Mayo, MD
Privatewrench
19
Kentucky
Son of a buck! Taking radiator out of my deuce. One bolt on the bottom stud came off easy, the other one I barely put pressure on to turn the nut and the bolt sheered right off. It was pretty rusty, so I've been shooting it with pb blaster for a couple weeks now. Anyone have this happen to them? Any fix ideas? Maybe I can weld another bolt on where this one broke. So much for a quick job:doh:
Iron Maiden
112
Oregon
Where'd you get that boot from? I haven't seen that style before.
Thanks everyone. My shifter boot was fabricated in our shop. I made it out of a 1/8" Aluminum and milled out the center. Then I drilled the holes and deburred it and lastly engraved it on an engraving machine, before painting. The rubber was just some stuff we had laying around that I cut to match the plate. The floor in the truck was tapped for the 10-32 blackened stainless steel screws. I'm not sure if I have time to make more, I might consider it. I'm also not sure if I could charge a price that people would think is fair.
SCM35A2
3,388
Florence, SC
Still making progress, I removed the air filter casing & sanded the majority of paint runs out of the old paint. I also stripped the old paint off the air cleaner mount, got the splash guards painted one last time, painted the air intake & did some more painting under the hood...
SCM35A2
3,388
Florence, SC
More progress...slow going, but I'm getting things done. Got the air intake cleaner primed up & painted, also touched up the firewall some, cleaned up the air intake couplings cleaned up & the driver's side rear splash guard installed along with the new mud flaps. Yes I know the flaps are longer than what comes from the military, but I don't off road this truck so its all good...
Wolfgang the Gray
36
New River, AZ
My boots both got tears in them so I bought a set of new RockwellOffroad silicon boots to replace them. This was my first time doing the boots so I went really slow & double checked everything as I went. I only got one boot done, but will do the other one on my next free weekend. I got green boots so they should be easier to tell if they are damaged compared to the old black ones. Instead of using Duct tape to cover the spline threads, I used an old soda can (trimmed off the top) and it fit right over with no sticky residue! I swabbed out all the old grease & replaced it with Lucas Oil Red N Tacky.
IMG_20200110_135950_01.jpgIMG_20200110_140003_01.jpgIMG_20200110_140003_02.jpg20200110_140656_HDR.jpg20200110_140700_HDR.jpgIMG_20200110_152647_01.jpg20200110_161330.jpg20200110_161335.jpg20200110_161338.jpgIMG_20200110_142801_01.jpg
FloridaAKM
395
Gainesville, Florida
My repairs were not that mechanically involved today after work, but my speakerman backup lights didn't work the last trip to work for some reason. After chasing down the problem with a VOM, I discovered the major problem in most military vehicles had settled in my lighting...a bad ground (go figure) It is all good now & maybe I won't back into anything else important @ 05:30 when getting to work.
Maverick1701
208
Lubbock, TX
I bought a new battery monday...$200 from my OReillys in Lubbock, TX. I thought about going with group 31s but in the end I really wanted to keep it as original as I can...so I saved some extra pennies and ordered a new 6tl.
the counter guy was telling me about another local deuce owner who is allegedly doing a 5.9 swap...now I need to find this guy so we can be M35A2 BFFs
today the weather was terrible (high 36* with rain/freezing rain). Tomorrow should be better....if all goes well, tomorrow I am going to throw on the new battery and get the truck running so I can circulate the algae biocide (I'm having my own little algae jihad) throughout the fuel system. I'm all stocked up on fuel filters so let's kill some algae!
