Great!!! I really want one! No, you can't really leave the December winner out. I'll wait patiently.Hi Tim! Merry Christmas to you and yours! Your post made perfect sense to me! Are you coming out with a 2022 MV Calendar?
I'm retired too. I use my calendar to note which days I have to pay bills on or water my houseplants. More like an appointment book with cool MVs on it.Auggh. Calender ?
im retired now , do i really need to know what day it is ?
Good AM it cut the cable right at the tongue I would have about 9” sticking out I need to replace it allhgun, would the trailer cable still be long enough to use if you took the end you show with the wires splayed out and reconnected them into the plug? A mid-wire splice is not a good idea. Don't feel too bad about the mistake. I was doing a K-turn in my driveway one day and forgot I had the tailgate down. I hit the corner of my house pretty hard. Enough to move the wall studs, h.w. baseboard and crack the sheetrock inside. I had to Smack the studs back straight with a sledgehammer from the inside of the house. Now that is what I call dumb!!!
.Auggh. Calender ?
Auggh. Calender ?
I did mine today, works great! Thanks for the hintThe original plug has 3 terminals. One of them is the short wire that is ground. You do NOT need that ground wire. The other two wires can be hooked to the EG22 in any fashion, any direction.
Use a multimeter to verify the ground wire if needed.
Here is a pic for reference, it’s not mine, but shows the plug end. Terminal “C” is ground, which can be found in relation to the “notch” in the plug. “A” and “B” to the EG22.
.I fired the poor girl up in the 5 degree weather, walled off the rad and mixed in enough extra coolant so I could accurately test the mixture for the brutally cold weather thats coming in. It was, ah, significantly less then impress... but it fired up and got as warm as it could for the temp its in and not being under any load. Coolant tested good for 40 below so it should be fine.
.Since I figured out my brake issue (separate thread) of one wheel being way out of adjustment and it's too cold to address
I decided to work on the interior. Pulled the seats to rework. OMG that spring seat is heavy! Found some cracks in the frame and generally in good shape but very dirty.
Found a NOS seat frame for $75.00 plus freight of $268. Think I'll try my had at welding this first.
ldmack3...Those shipping costs can be a killer. The ragged hole in your third picture looks like the result of corrosion to me. It can be hard to fill a hole like that with a mig welder. If you're not careful you can end up burning the hole even bigger. Ask me how I know. I'd be tempted to cut a small steel sheet metal patch, hammer it into shape with a mallet, and then weld the patch to the tubing over the hole. Kind of like a weld on bandaid.Since I figured out my brake issue (separate thread) of one wheel being way out of adjustment and it's too cold to address
Yep they both got bigger before they got smaller! I did end up welding a patch over the large hole after I removed some of the rusted this metal. That was a new experience for me. Trying to make a patch from 16ga with a double curve. Got both done with decent welds. Almost getting good at this.ldmack3...Those shipping costs can be a killer. The ragged hole in your third picture looks like the result of corrosion to me. It can be hard to fill a hole like that with a mig welder. If you're not careful you can end up burning the hole even bigger. Ask me how I know. I'd be tempted to cut a small steel sheet metal patch, hammer it into shape with a mallet, and then weld the patch to the tubing over the hole. Kind of like a weld on bandaid.
That is one clean looking interior dieselfitter! Mine used to look that good years ago. I had a feeling your problem was the cable. They're stranded cable if I remember correctly. After a while the get weak or break. Glad to hear you found the problem!I hope the new year brings everyone some peace and happiness.
i added a hardtop this week and it really keeps the heat in ,
the fiberglass reproduction didnt fit to clean. , had to shim the windsheild frame up an inch wih some sq stock tubing , and a thicker gasket.
added a rifle rack , and pistol locker behind the seat.
i havent customized a truck this much since i used to rock crawl yrs ago !
the real news is that i FINALLY got the speedo working again ,
i found the .222 gear for tranfer and bought cable , mine was broke right where it goes into back of speedo , it was a pain to get that lil broken piece of cable out . I gave up three times ,but kept going back to it. I hate gettin beat by a mechanical thing. Now everything on the truck works .
rain cleaned the salt off the roads this wk so i delivered more logs to the mill , cold coming again tonight , so the truck goes back in the box and waits for another workday. View attachment 854845
