- 14,713
- 5,135
- 113
- Buchanan, GA
Threw more garbage in it to haul off to the dump eventually...
I might even crank it sometime this week.
Take a thin piece of sheet metal (stainless steel or second choice aluminum), about three inches wide, bend it about the same shape of the radiator hose and use a hose clamp to install it. Piece of cake!After replacing the thermostat I noticed I seem to be missing the sheet metal piece that protects the upper rad hose form the belts. I have no idea what it looked like. If some one could maybe take a photo of one I could make something up.
Hello Rsh,Installed headlight wireing harness from LMC and new headlights from Hella,awesome lights and replacable hb2 bulbs,also added batt. bolt extender into previously unused pos. sidemount to hook accessories to.took about an hour,and pretty easy..
Hey rsh, what model Hella's and where did you get them? Price please? Thanks!... new headlights from Hella,awesome lights and replacable hb2 bulbs ...
He's got Optima Red Tops, Jay. They have both the regular top mounted posts, and the GM-style side-mount connectors. Like this:Hello Rsh,
What do you mean.. "sidemount to hook accessories to..."? Any pics of it?
Sounds interesting...
Hi guys,
Okay, I grasp the concept and look now...
Sounds good...
Take a look at this. If you want the best, this is it.Since my batteries are top post only, I would have to figure out some safe way to hook accessories directly to it too.
That's a very clean way to do it.Maybe mount a small bus bar or fusebox, etc. near the batteries, and run a positive to it, then hook all accessories to the bar, that way there are not multiple accessories hooked to the battery..
Hello Rsh,Scottladdy, Hella 003427291, from Summit Racing 46.95 each,I put a set on my 79 Malibu and loved them,then discovered same ones fit 1009,had to do it..a little pricey but its worth it to me, im 48 and eyes are not what they used to be..and the sylvania high end headlights are nice and half the price,but at 150 hr. life not worth it,with the Hellas you can replace bulb,not whole unit,also you get many more bulb choices with the hellas which use a hb2 bulb..deff. do the headlight harness upgrade tho..If you can get the DogHead headlight harness upgrade I would go that route as my LMC harness was made in Taiwan....LOL...
Yeah, it's pretty slick. I used to install cellphones (back when they were carphones) and business two-way radios, and this was the best solution for a GM style battery. It's very popular with stereo installers for the same reason.
http://www.hivolume.com/en/select.php?aftermarket_part=7372
You can also install a fuse block right there in the engine compartment that uses standard ATC automotive fuses. Very clean, neat, and easy to troubleshoot.
http://www.delcity.net/store/8!way-ATC®-&-ATO®-Automotive-Fuse-Block/p_10823
(I'm not recommending the dealers linked above - just found them with a quick search to show what I'm talking about. I don't know them at all.)
