1ton cucv k5 turbo
- 0
- 18
- Castalian Springs, TN
thanks, the M series headlight buckets that I got from Popacom (I think I got his last pair) are a perfect fit between the rails on the grill gaurd. What is nice about them is you can mount them even and then use the adjusters in the headlight housings to aim the spotlights. You do not have to try to aim them with the mounting brackets. I should have taken a pick of the metal that I started with. I actually pulled some metal angle brackets out of the scrap pile and cut them up to make the pieces. These brackets were used to strap computer cabinets to pallets for shipping. I had them in my scrap metal pile for about 5 years and finally found a use for them.
I still need to get them wired up and then adjusted but I already have the switch in the dash and the lights mounted I now need to get the wire and relay's installed. I am shopping for a 24V relay that I can use 12 volts to actuate. I think I need relays that will handle 20 amps for each pair of lights.
Cool.... let me know how/where you sourced your relays.... i still need to finish wiring up my aircraft landing lights i have on the front of mine.....
