- 2,480
- 24
- 38
- Houston Texas
I just finished installing my new engine about two hours ago. It runs great, But the passenger side freeze plug behind the motor mount is leaking water. Looks like i've got alot more wrench turning to do.
Get a funnel and a Military Fuel Spout for that can. You will absolutely loathe that nozzle.Ok So just a few more things to add... I have replaced my rear window crank, mounted a 5 Litre fuel tank in the rear, jimmy rigged a wing nut for the spare using misc parts from the hard ware store. I also have a new center console and a power inverter I plan on plugging accessories in. I added a couple of exterior pictures for fun. Enjoy.
What kind of lift did you use? Cost?4 inch lift on M1009.
Before and after pics.
Have one just not in the picture... I know about the donkey d--k!!!Get a funnel and a Military Fuel Spout for that can. You will absolutely loathe that nozzle.
How has the lift worked out? Was thinking about a 2" lift but most manufacturers don't make one for diesels - say the rad will not get enough airflow when the cab gets lifted.Replaced some dash lights. Removed the gas can mount in back. Installed inside rear view mirror. Wednesday new bushings, body mounts and 3" body lift.
I also learned the hard way that my fuel gauge is off. I had the wonderful opportunity of learning how to bleed the fuel system. Not a big deal, but I had to go into town to get a pump to help with bleeding.Replaced Fuel Filter, topped off fluids, basics like that.
