What have you done to your CUCV today/lately? - Part 1
Colo.
Nice little mod today.
Found a heavy stainless steel loaf pan online:
A quick trip to Ace for some hardware (clasps, handle, nuts & bolts), grabbed an old clamp and a bent a jeep license plate bracket, and viola, road food baby! Perfect for hot dogs, burritos, corn, whatever.
Lurchwolf
Bellevue, Washington
Tear down
Well, I pulled out the motor yesterday after a loud bang and lots of smoke. Tore it down today and found two cracked/burned up pistons, one with a hole and a melted injector.
The block and heads look in great shape, but I just don't see it being worth the cost to rebuild such an already mediocre motor.
Time for a 454, I think. :p
chevyCUCV
Massachusetts
Bought a 85 chevy 1/2 ton for parts
Stripping the sm465 and np205 for my 1008
Hopefully have a rebuilt trans/transfer case with twin sticks installed in the next couple months....
idM1028
Somewhere in Nebraska
Dropped in a K&N air filter (14" diam X 4" tall). Did the doghead starter relay mod (Note: I had some trouble with the ring terminals. If you're going to use ring terminals, might want to use one with a smaller size connection relative to the ring or be prepared to do fabbing.) Getting new Firestone tires on Thursday.
wrex
9
Laveen, Az
Changed the oil last week and drove it from San Francisco to Kansas City.
FYI: 950+ miles of I-80 is one boring ass drive and Salt Lake City, UT smells like poop! lol
darkserra
Kansas
I'm currently installing a Nostalgic Air Parts complete A/C system. Had to remove the old heater core to install the evaporator. Took off the front grill to get the condenser in (would have been much easier if the previous unit hadn't bent in the brush guard by running into something), then had to pull the fan shroud, fan blades, crankshaft and power steering pump pulleys. Replaced the water pump (had to pull the d*** water crossover to get the LAST bolt out of the water pump) and thermostat. Removed the right alternator to clear the way to put the a/c compressor tonight.
hotdogs151a2
14
Bullswamp,SC
Just installed the world famous Mr. Doghead starter relay upgrade on the M-1028. The only problem I had was my old wore out back. The change out came off without a hitch. Now I will do the M-1008!
The NAPA relays cost me 13 dollars and some change with my retired military discount. Thanks, NAPA.
Thank you Sir.
Hotdog
Darwin T
10
Port Arthur, Texas
it would have benn nice, however, i was on the other side of missouri. check out my thread "General Lee Euro Farquaad" read about my time in missuori.
i am planning to install the pto generator and air compressor in the maint box like most of the M1031s came with.
DrJekl
Clarksville, TN
I fried a starter, cooked a wiring harness, took a nail in the sidewall of my tire, and put a nice dent in my M1009. then I pulled out the dent, replaced the harness and starter, charged the batteries, and have not finished the project.
Cucvnut
75
Carver, Oregon
I killed an ip fired a starter re placed both stuck does still not run.. i know how that feels.
