gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 748
- Cincy Ohio
UHH, no. That info is wrong. On a ford or chevy, that might work, NOT on a deuce.What is the air temp when you are trying to start.
Use your preheat for 60 seconds, then start for 20 seconds while holding half to quarter acceleration pedal continue with heat until motor smooths out a little.
If no start, repeat above.
If it is below about 25 you may want to hit the either for about two seconds.
But, If you use either I don't know if you can use preheat. I don't combine preheat with either because of risk of explosion or fire.
I have never had to do the flaming rag thing. Would not like the stuff in my motor and I don't need more injuries.
A better source of info is the operation manual. I bet they are posted on this site
I always hold some pedal (half to quarter throttle) when it's a little cold or I know the machine is slow to start.
One thing for sure, diesels love hot batteries; shinny terminals and cable connections and big fat copper conductors.
If you know its going to be cold for a while I think a diesel anti gel additive is good.
I have filled filter cartridges with half anti-gel and half diesel (super cold and had to roll), but never confirmed this with double blind scientific study.
As far as working on the diesel. Your in luck. It's much easier than those crazy gas things.
If you have compression, and your fuel is getting to the cylinders, and your motor is turning over fast enough, the dam thing is going to go. So be careful ! Don't bypass your safety mechanisms. Make sure you are in neutral with the break on. And make sure no one is standing in front of or behind the truck.
Probably good to check the valve adjustment after the first 100,000 miles.
Change the fuel filters? I don't know, annually if your driving 10k+. But if not stretch it out a little. If your tank is rust you may need to chge the fuel filters more often.
Let us know how the truck acts.
Best to Ya
You are supposed to use your intake heater WHILE CRANKING.
You guys shouldn't post BAD INFO
There is no glow plugs on a deuce.
