74M35A2
- 313
- 83
- Livonia, MI
Its called a companion flangeMine has a 250 cummins and we did use the original bellhousing. There was a spacer on the end of the crank that had to be removed and a spacer put on the starter to shim out correctly. Yes im refering to the drive shaft between the transmission and transfer case. We had a drive shaft out of an oshkosh that had the round flange same as the axels. Yes they make a wing style yoke for a fuller but its larger. Weller truck parts is who we buy all are semi parts from and they couldnt find anything close. I swapped the input yoke on x-case tothe same as both out put shafts. The large pto on the bottom is directly over the front drive shaft.
Interesting, thanks. Because you used the longer flywheel housing, I wonder if your trans input shaft is in the clutch and flywheel pilot bearing by 1" less. From measuring the "standard" flywheel housing depth I bought, the 5" depth housing is required to avoid this. If I used the 1" deeper flywheel housing, the clutch discs will still be on the trans input shafts, but the tip of the trans input shaft would not be supported by the pilot bearing anymore, it will be 1" rearward, hanging in space. 250 engine should be the same situation, and removing any flywheel spacer would make it even worse.Mine has a 250 cummins and we did use the original bellhousing. There was a spacer on the end of the crank that had to be removed and a spacer put on the starter to shim out correctly. Yes im refering to the drive shaft between the transmission and transfer case. We had a drive shaft out of an oshkosh that had the round flange same as the axels. Yes they make a wing style yoke for a fuller but its larger. Weller truck parts is who we buy all are semi parts from and they couldnt find anything close. I swapped the input yoke on x-case tothe same as both out put shafts. The large pto on the bottom is directly over the front drive shaft.
