Another Ahab
- 4,982
- Alexandria, VA
mann650, if you pick up an M105 trailer you could name it "half" so together you have a "Zeus &a Half",
The Gods of The Green Iron are always listening, looking for a laugh.Nothing like waking up to a low tire in the morning. And I was just thinking the other day how long it has been since I had tire trouble
It's your truck trying to tell you something. Maybe it dreamt of MRAP rims and tires!View attachment 768131 Nothing like waking up to a low tire in the morning. I'll load a good tire in the pickup and drop it off at the tire store, then drop off the Deuce and have them swap tires. And I was just thinking the other day how long it has been since I had tire trouble.![]()
Working with tube tires at home is not an insurmountable problem. Many commercial shops will not do them as few have been fitted to commercial trucks for the last 20 years and many tire mechanics have never seen one. Also most shops will not mount a tire that is over 10 years old. An impact wrench aids in lug nut work (remember the ones on the driver's side have LEFT HAND threads). If a shop air com pressor is not available electric ones are available, some of which plug into the slave receptacle on the truck. The truck can also furnish air to inflate the tires. For really stubborn cases a breaker bar with 1.5" and 13/16s square will start them especially of the lug nuts have not been off in 20 years and are fouled with paint or rust. A tire inflation hose with 10' or so o line on the downstream side of the valve and a clip on chuck is recommended. When I was in the service with a 20 year old M818 under me, the motor sergeant let me carry an extra tube and I had a hammer and some lock ring tools and I would pull the nail out of the tire, install the tube, inflate it and move on. The tire in post 9162 appears to be cupped from the solid front axles causing the lugs on the NDT tire to wear on 1 side. This can be equalized by rotating the front tires to the opposite side or moving them to the rear.
I always carry the military reduction lug wrench with me at all times. That and a long bar like you have pictured. Plus now I also carry my 1" air impact wrench.View attachment 768233Working with tube tires at home is not an insurmountable problem. Many commercial shops will not do them as few have been fitted to commercial trucks for the last 20 years and many tire mechanics have never seen one. Also most shops will not mount a tire that is over 10 years old. An impact wrench aids in lug nut work (remember the ones on the driver's side have LEFT HAND threads). If a shop air com pressor is not available electric ones are available, some of which plug into the slave receptacle on the truck. The truck can also furnish air to inflate the tires. For really stubborn cases a breaker bar with 1.5" and 13/16s square will start them especially of the lug nuts have not been off in 20 years and are fouled with paint or rust. A tire inflation hose with 10' or so o line on the downstream side of the valve and a clip on chuck is recommended. When I was in the service with a 20 year old M818 under me, the motor sergeant let me carry an extra tube and I had a hammer and some lock ring tools and I would pull the nail out of the tire, install the tube, inflate it and move on. The tire in post 9162 appears to be cupped from the solid front axles causing the lugs on the NDT tire to wear on 1 side. This can be equalized by rotating the front tires to the opposite side or moving them to the rear.View attachment 768231View attachment 768232
Wait a second.I always carry the military reduction lug wrench with me at all times. That and a long bar like you have pictured. Plus now I also carry my 1" air impact wrench.
That is a 22.5 rim and tire on the trailer, I have a total of 13 of them which I plan to have powder coated and mount something like these on them.
I noticed the tire off the trailer that I put on the front of the truck is a bit low on air after I put the compressor away. Well I have a couple more tires to switch around tomorrow. I have had too many tread separations on other vehicles to feel comfortable running older tires anymore, and I kinda like the original dual rear tire set up over being "singled out", but that is what makes this hobby fun, like burger king, you can have it your way.
Looks like you are on the right track. I just did mine. Hardest part is the end of the fuel tank that has no access. Did the best I could and am letting the bio clean and fuel filters do the rest.Yesterday I finally had the time to dig a little deeper into my alleged "algae in the fuel tank" issue....and yup, it's definitely the green scourge.
I found a nice layer of algae on the bottom of the tank (I'm assuming there is some water build-up at the tank bottom which kicked off the algae growth)
We return from our honeymoon on July 3rd so I'll have to wait until then to drain, uninstall, clean, & reinstall the tank....and then change fuel filters (probably more than once as things clear out)
I was going to probably clean the tank with acetone (after draining & removing from the truck).
Do y'all recommend another technique and/or product I should try first?
fuel tank strainer before cleaning....totally clogged with algae
fuel doesn't look too bad
Scrapings from the fuel tank strainer
fuel strainer post cleaning with acetone...nice and clear.
Modern low sulphur diesel will dry up and turn to gummy goo like modern ethanol gas, especially left sitting in the heat. I've had it happen to varying degrees each summer. If it dissolves into nothing with acetone, that is likely the case. If it does not dissolve, and there are solids left after acetone, it is likely organic growth. Optilube summer blend seems to help, as does keeping the tank full and running the truck periodically. Ideally, I would use up all the diesel and park it for the summer with clean waste oil in it.Yesterday I finally had the time to dig a little deeper into my alleged "algae in the fuel tank" issue....and yup, it's definitely the green scourge.
