Deuce with Cummins 6BT Info thread
HanksDeuce
263
Prairieville, LA
davidb56
1,238
Bonners Ferry Idaho
be
The intake piping looks funny on that truck. My truck has the turbo compressor inlet closer to the radiator, and the exhaust dumps into the downpipe near the firewall. It looks like this truck has the compressor inlet piping on the firewall side, but how is the downpipe routed near the radiator?
Eastern's 6bt pic
My 6bt engine pic
because yours has a intercooler, and the other one doesn't......
HanksDeuce
263
Prairieville, LA
I don't think so. Here's another one without an intercooler (from page 1 of this thread). Air filter feeds front of turbo (not the firewall side). Of course the turbo in the picture below sits up much higher than the Eastern Surplus listed engine.
I have no clue if there was a contract with plans on one way to do this, or some of these pictures are custom M35A2s with 6BT builds like mine.
davidb56
1,238
Bonners Ferry Idaho
the one turbo is flipped. air side is at the rear, the one in this pic has the air side in the front. 1989-91 cummins 5.9 were not all intercooled. Also follow the air intake manifold to the turbo, it would be going to the front of the engine if it was intercooled, as the intercooler would be in front of the radiator....Both are piped right back to the turbo.
radog3
Rochester Illinois
I'm hoping to figure out the story on my cummins conversion 71' m35a2. The tan cummins in the first picture is mine and I couldn't help but notice the alternator bracket is the same as the second picture. I've since swaped in an aftermarket radiator because the original was torn up by the winch cable when I bought it. The other pictures are my engine mounts etc. I'm just curious if the military actually converted a few of the trucks themselves or if a company was selling a conversion kit.
Holger
Brazil
Eastern's 6bt pic
My 6bt engine pic
Hi, writing you from Brazil. I´m not sure whether the truck with intercooler aplication is yours - but even if not, maybe you could tell me who can give me some hints about - thinking about putting it on my M35AC Cummins 6BT
HanksDeuce
263
Prairieville, LA
The M35A2 with intercooled 6BT is indeed mine. I ended up having to use a longer military truck hood (dump truck?) because the radiator/intercooler assembly stuck out too far.
For more information on fitting the intercooler visit the following, https://www.hanksdeuce.com/intercooler_mods.htm
GM-M1008
Weatherly, PA
Mines intercooled. It actually has a cummins part number on it if you’d like. Fits behind the stock grill and hood.
GM-M1008
Weatherly, PA
... also if you had some images of your application, would be very much appreciated
I’ll get the part number off it when I’m at the truck.
