coachgeo
- 3,553
- North of Cincy OH
I need bracketI’m in the process of doing this same conversion and I have an extra Compressor mounting bracket for sale if anyone needs one.
will PM you
Pm sentI need bracket
will PM you
Jean, I think everyone appreciates your interest and enthusiasm for these trucks, but you should really create your own thread with your questions. This thread is about the air conditioners. By mixing topics, it is considered bad form. Also, it can make these threads less useful for people wanting to learn about one specific topic.Where did they hide the flasher for turn signals
Sent from my SM-G892A using Tapatalk
No worries, we all were new here once. Welcome to the site. You will find a lot of really great people here.Sorry I'm new......
Yes, they are listed in the TM.You will find a lot of really great people here.
There's actually 2 blank prongs....it kinda scares me to send 24 volts the freewheel ac fans....never did like electrical.....just don't understand it.....In the upper left corner of the instrument panel is a switch that will apply 24v to the fan control solenoid valve and force the fan to freewheel/keep it from engaging. It is for driving into/fording deep water where a coupled fan might get damaged…
My experience is just don't let any of the magic smoke out.never did like electrical.....just don't understand it.....
I'm new also and looking for them same. From what I can tell the 3126 would need the same brackets. Anyone know if any of the A/C kits I have seen in the recent past on GP coming out of Yermo would contain any useful parts for LMTV? Also, I see a similar looking unit in a RedDot catalog to the picture on the first post of this thread. Not sure if it is available to the public, I haven't researched or inquired so anybody have input? Also, what are the chances of a civilian truck with a 3126 motor in it having the brackets for the left side install or are they installed on the right side under the alternator? Thanks for any input.Man. What a ton of info in this thread. But, I'm late to the party.
I'm hoping to get A/C added before summer arrives. I think I can find most of the needed parts, but I'm looking to support the folks here if I can.
Hoses, fittings, basic wiring etc... I can source locally. The compressor, dryer and switches I can just source online.
I figure I need:
Both driver side brackets for the 3116 (or there was some mention of a passenger side conversion with place for a/c and 200A alt)
Pulley for the 3116
condenser unit
Gen2 evaporator unit
Anyone have any of this left for sale?
I'm not 100% sure with the 3126, but I looked at the 3116 that GM put in some of the Topkick trucks. Every one I found had the A/C brackets on the passenger side, which was made possible by running a much smaller civilian alternator on that side.I'm new also and looking for them same. From what I can tell the 3126 would need the same brackets. Anyone know if any of the A/C kits I have seen in the recent past on GP coming out of Yermo would contain any useful parts for LMTV? Also, I see a similar looking unit in a RedDot catalog to the picture on the first post of this thread. Not sure if it is available to the public, I haven't researched or inquired so anybody have input? Also, what are the chances of a civilian truck with a 3126 motor in it having the brackets for the left side install or are they installed on the right side under the alternator? Thanks for any input.
Gary
The Topkick installation position doesn't clear the LMTV doghouse.I'm not 100% sure with the 3126, but I looked at the 3116 that GM put in some of the Topkick trucks. Every one I found had the A/C brackets on the passenger side, which was made possible by running a much smaller civilian alternator on that side.
				Very clever setup…The Topkick installation position doesn't clear the LMTV doghouse.
I build and sell a kit for the 3116 that uses a commercial 200A 24v alternator.
Nope, none available.You can find the gen2 evap/blower on Ebay still.
dual voltage? the LMTV requires that.The Topkick installation position doesn't clear the LMTV doghouse.
