- 1,172
- 31
- 48
- Galesville, WI
I picked up a new used tool last week for $40. I hooked it up to the pump for my shop press. It does the job, but the air/hydraulic pump is a must. I had to reposition it 14 times and pumped for 20 minutes to get the bead pushed down on both sides. I see HF has them on sale Monday for $109 with the 25% off. It would be a 5 minute job with the correct pump.
I have a wheel that will not bead up. The tire won't go over the tapered edge of the split ring. It just does not seem to fit right. It is better to fill the wheel full of wood, burn the red paint of the wheel and toast marshmallows than to blow an arm off.
I'll blast the wheel and get it painted next.
