What have you done to your FMTV or LMTV today
flyfishtrailer
988
Cool, CA
Gonna do the parade of lights next weekend and all of the lights I ordered arrived today so why not get them on the truck. Santa will ride in the back and will be lowered to the ground in my crane. We are working on a chair for the crane this weekend. Should be a blast. I will post pictures after the event.
Third From Texas
6,336
Corpus Christi Texas
So the burning question now is this. Do I try and find someone with a tan top who needs a camo top and trade? Or do I paint the truck to match the top?
Saw this one kinda out your way...
EDIT: nevermind, they are for an MTV
serpico760
1,575
San Diego, CA
Thought I would post pictures of my nearly complete custom interior i built for my M1083A1.
I measured and remodeled an FMTV CAD model I downloaded, designed everything in SolidWorks, cut the panels from tempered fiberboard, glued on foam mylar insulation in the back, and screwed it into the cab after I dynamatted and filled every crevasse with foam sheets and spray foam. Next is a radio console in the top middle, and top side panels.
serpico760
1,575
San Diego, CA
I measured and remodeled an FMTV CAD model I downloaded, designed everything in SolidWorks, cut the panels from tempered fiberboard, glued on foam mylar insulation in the back, and screwed it into the cab after I dyna-matted and filled every crevasse with foam sheets and spray foam. Next is a radio console in the top middle, and top side panels.
My friend Dave just installed my new puck lock holders... Get yours today!
If you look closely at my interior photos I previously posted you can see a few of the other items I've designed, they will come available soon
serpico760
1,575
San Diego, CA
Nice…. I thought that was your tobacco holder.
Did you post it for sale yet?
I don't partake of any sort of tobacco, but you're welcome to use it for that!
Very first thing I did to the truck when it was delivered to my friend's ranch was installed these hasps the next day using Dave's video as reference. Then a few months ago I installed the door handles using the videos of endless adventure for reference.
Mavcaster
418
Maryland
Do you have a link to the video for the door handle replacement? I can’t find it on their channel.
serpico760
1,575
San Diego, CA
I posted the part numbers and everything before but here it is. I have included a template Don't print it out but rather make your own based upon these dimensions. It includes the dimensions to the edges of the door. When I mounted it like this slightly different than what he mounted it as in the video You don't need to modify any brackets. You do need to cut the access hole in the back but not necessarily as big as he did or as big as I did. The window pane came close to the bracket in the spring so I cut some flexible plastic sheet such that the window slides over it and doesn't touch. IMG_20220730_130819.jpg
serpico760
1,575
San Diego, CA
