ECO Hubs Who needs 3:07 gears?
Keith Knight
1,597
Wauchula, FL
After the EcoHubs and the original 3.90 gears are installed. when I take it to caterpillar service to have them reprogram the eco speedometer doe anyone know the ratio? I think it was a ratio that was needed, its been 6 or 7 years ago that I had them change it for the 3.07 gears. Or is that something I can program myself using the software I got from Superman? Also why is the overspeed on the CTIS recommended to delete it?
AKPacker
Anchorage, AK
The stock number for my speedo was 62,618 pulses/mile, so you'd want to halve that with the Ecohubs and 3.90 gears. You can program it yourself if you have the Cat ET software and adapter cables.
GeneralDisorder
4,566
Portland, OR
If you like, you can send me your ECM and I can flash it to 330 HP and make all the changes for pulse per mile and cruise enable, etc. Can also clone the ECM if you want to carry a spare. CAT generally can't or won't do that with a used ECM and new ones for the 3126 are crazy expensive from them. I can turn around an ECM in 1-2 business days.
Ronmar
6,947
Port angeles wa
@Keith Knight I don't know if you can reset it in the CTIS controller, but you are basically feeding it 1/2 the pulses it would normally see, so you would have to be going twice as fast as the original set overspeed alarm point to actually activate it, so you should never see it ever again:)
GeneralDisorder
4,566
Portland, OR
When you reprogram the A1+ truck ECM to correct the speedo that same signal is used by the CTIS controller so it will go to over speed warning at the same ~65 mph that it always did. But you can pop into the Dana software and change the HWY over speed warning to whatever you want.
Keith Knight
1,597
Wauchula, FL
So if I have caterpillar program it they need 31,309 to enter into the ECM? I thought it was a percentage that they needed.
Keith Knight
1,597
Wauchula, FL
Thanks Rick, years ago my ECM died and I purchased a new ECM from cat and they programmed it to 330, activated cruise, set cruise setting to the lowest mph possible and saved the data for future needs. I’m may send it to you just for back up reasons. What’s the charge?
Keith Knight
1,597
Wauchula, FL
That’s what I thought so I wasn’t sure what the delete was recommended for in the directions.
