CARC686
- 708
- 93
- New Mexico
Got a tub of spare Rotella stashed away that'll do it. In the meantime, share a touch of Jimmi with me. Helps me worry less about whatever I've probably screwed up.
thanks, man. Hinges were my problem. Once lubed, hood opens like in new carLube up everything really well in the latch and hinges. The hinges can be tricky since they are under the cowl. Real motor oil in a squirt can works best. Spray lubes are a waste of time. Good Luck.
No there's the spindle that has to come off first. There's 6 nuts that hold it on if I remember right. I've used several methods of getting it off after they're taken off. A big dead blow hammer has worked on non rusty ones and a nice sharp cold chisel for the sticky ones going around the outside to work it loose. Not a horrible job. As far as the ball joints I've always bought 2 very cheap pickle forks and beat them both into both ball joints at the same time. Typically they'll work 2x before they're destroyed hence the cheap ones get a warranty out quick. I don't think it's worth spending money on the expensive ones...they'll replace those as well but cost a good bit more. I'm not nice to those pickle forks...get hit with a 20lb sledge.Alright, I needed a tool I didn't have and then another I didn't have and then another and another. I swore I would not collect up a complete suite of mechanic junk after I retired, but it looks like it's happening anyway.
I'll get after it again soon, but I have a question first. Should I be able to just yank the half shaft out after I pop the spindle off, or is it gonna have a clip in the pumpkin? If there isn't a c-clip in there, is it gonna dump gear oil everywhere when I yank it out anyway? Really would prefer not to have to service the front diff quite yet. Just need the half shaft out of my way so I can knock out a busted ball joint. I did not sign up to rebuild an axle. Feeling like I gave a mouse a cookie right about now.
Just for reference, it's an OEM M1009 10 bolt. Confusion between the M1009 and M1008 has made my life more interesting than it needed to be in the past.
I hope that is a Walmart cakeI started out a regular photojournalist on this truck, but something about handling grease in a sandpit made me lose interest in taking pics.
Step 01: Take off the locker select thing and realize you need snap ring pliers.
Step 02: Wait a week for the snap ring pliers you ordered to show up.
Step 03: Realize you need a weird socket.
Step 04: Wait a week for the weird socket you ordered to show up.
Step 05: Pull all the greasy doodads out and be sure to drop them in the sand.
Step 06: Spend all day cleaning the grease and sand out of the greasy doodads.
Step 07: Smear bearing grease on the porch, door, floor, your hands, arms, and face, and be sure to get it on the soles of your shoes.
Step 08: Beat the spindle off with the heaviest non-marring thing you can find.
Step 09: Grab the axle and yank it out. Be sure to drop the oily end in the sand.
Step 10: Sing a chain gang song from O' Brother Where Art Thou? while attacking your pickle fork.
Step 11: Reassembly is sorta kinda reverse of disassembly.
Step 12: Blast the surface gunk off with aerosol skin cracker.
Step 13: Spray the bare metal with grill paint 'cause it's cheaper than engine enamel.
Step 14: Squeeze your caliper with the ball joint press when you can't find your c-clamp.
Step 15: Drive it around until it gets done smoking.
Step 16: Go to the car wash and spend 10 minutes pressure washing baked bird shit off your truck.
