- 4,210
- 37
- 0
- Las Cruces, NM
Well, I don't really need it (FDC) as I only run Diesel, and, I really don't want to discover my truck is making oil when I'm a long way from home.
i would get rid of it just to be safe.i talked to my engine builder he contacted arp they said the have a rod bolt that will fit the multifuel rod .even though they dont have it listed only catch the rod needs to be sized as they ussually are distorted from the knerlled area of the old bolts.they have more that double the tensitle strenght of the stock bolts which are just a little better than a grade 8![]()
Hopefully a head gasket, not a crack.Well, today I took the truck for a test drive, with the doghouse uninstalled, and I have antifreeze running down the back of the block. . .
Not a hose issue, I can see where the liquid is coming from between the head and block in the vicinty of the #6 cylinder. . . . Frak!
Motor runs really good though![]()
Here's couple of pics. . .
I really hate changing motors. . . again. . .
What ticks me off the most is the $120.00 in fluids I put in this motor
From what I have read on these boards, the gaskets with the tabs that stick out past the head are the new style.I forgot, tabs on head gasket = new, or old style gaskets?
Don't even want to mention how much money in "fluids" I put in myself during this debacle. . .![]()
