goldneagle
- 946
- Slidell, LA
Felt energetic today so I decided to tackle the fog lights installation. I fabricated some tilt brackets from 1-1/4" x 1/8" flat stock. I bent it up into u-shaped brackets. One is slightly smaller than the other to allow one to fit inside the other. These brackets will become the tilt mechanism for the lights. I fabricated 4 pieces, 2 for each light. I primed and painted the brackets.
I drilled 2 holes in to the lower triangle bumper support on each side. Attached the brackets to the bumper with 2 bolts each. Then I attached the 2nd half of the bracket to the mounted half with 2 bolts on the sides.
Once the brackets were secured it was time to add the lights. I attached the ground wire from the fuse panel to the center bolt on the light and attached it to the bracket. Did the same tot the other side.
I ran 14/4 SJOW cord to through the firewall to a switch in the dash. The other end was attached to the 2 lights I just installed. I used the black and red wires for the hi and low levels of light. I used the green and white wires to ground each light.
In the cab I installed a 30 amp on - off- on switch in the dash. i ran a new line to the new fuse panel. I tied in the red and black to the hi and low screws on the switch. I attached the green and white wires to the ground bar on the fuse panel. Installed a fuse and the job was done. When I turned on the switch on one light went out, but the other was working fine. i tried the other element and both lights came on, but the bad one went out after a few seconds. I think the bulb had a air leak and the elements burned up.
I am attaching pictures of the install.
