goldneagle
- 1,465
- 113
- Slidell, LA
I finally got all the electrical parts in this week. The weather was nice today so it was time to finish installing the Mini-ANL fuse on the line that feeds the 124 volt fuse block. I had to also replace the 3/8" diameter bolt on the battery terminal clamp to a longer one so I could add the cable for the fuse block. After finishing the fuse block install I drilled 2 hole on the driver's side of the battery compartment. I installed 2 toggle switches that were fed from the new 24 volt fuse block. One switch will run the light over the driver's head and the other will run 2 lights over the passenger's heads. (this way I don't have to keep the light on over my head if the passenger needs to finds something in the dark)
I ran 2 conductor rubber cord to the switches from the fuse block with a 15 amp fuse installed. I ran a 4 conductor rubber cord from the switches to the lights in the ceiling. I used LED amber marker lights as dome lights in the cab. Got them wired in with a ground wire going all the way tot he fuse panel. This way I don't have to worry about a good ground.
See picture attached:
