Unsure about what you're saying here, DavidWymore:Tip: fitting saver for those tough ones.
Return line Bung leaks. Grind out the solder and weld? Tip: needs rubber hose here for flex.
Redundancy is real good for peace-of-mind...Thinking about one of these (air intake shutoff) maybe from a 5t. Partly for engine runaway but also thinking for brake failure. Shut that thing in gear and she should stop. I also have an exh brake I need to
install.
Nice work, Davidwyby. Electrical problems. Man! They can be so simple to solve...Alt quit, swapped it with known working one from the recently acquired thrown rod truck. Still no juice. No signal from main power switch. Duh. Should have checked that first. Tonight got lucky and found the short quickly. Got juice again.
