- 10,350
- 92
- 48
- Meadows of Dan, Virginia
I realize that this is a kind of "Low feedback" subject, but a lot of viewers are registerd, so I'll continue with my updates here for the sake of completion.
Using the control panel pictured above, the procedure will be as follows:
In cold weather (below about 60F):
1) Make sure the pump and return flow for diesel is selected ("AUX" tank)
2) Turn on the accessory switch and start engine. Use radiator cover to help warm the engine.
3) Turn on the "HEATER" switch to let coolant circulate in the "MAIN" fuel tank.
4) Observe the temperature gauges. It may take up to 1/2 hour to warm the engine and the fuel.
When the fuel temperature reaches 70 deg F or so, proceed as follows:
5) Switch to "MAIN" fuel pump, but let the return flow continue to the "AUX" tank, purging the diesel from the fuel lines/filters
back to the "AUX" tank. This may take 30 seconds or so. The "FUEL FLOW" warning light should come on.
6) Flip the "RETURN" switch to "MAIN" and the "FUEL FLOW" warning light should go off.
The engine is now running on heated fuel from the main tank and the return is guided back to the main tank as well.
Drive and operate the truck as usual. When shutting down, you will need to purge the biodiesel/veggie oil fuel frome the system.
Proceed as follows:
1) Switch to "AUX" fuel pump. The warning light should come on. Let engine run for about 60 seconds on diesel while pushing any
biodiesel/veggie oil out into the main tank. It's okay to have some diesel flow into the main tank.
2) Switch "RETURN" to "AUX" position. The warning light will go out.
3) Run engine for normal 5 to 10 minute cool-down period and shut it down.
I'm still doing some plumbing and there is some wiring left to do, but should be able to run some tests shortly.
Bjorn
1968 M49A2C modified.
Proceed as follows:
Bjorn
