- 5,766
- 3,193
- 113
- Metairie/La (N'awlins)
Pulse Tech Distribution System
I have one of these in my m923 battery box and very happy with it.
This is a sealed weather tight fuse box with 12v & 24v separate taps,storage for extra circuit breakers, and a battery pulse desulfating board. An external battery test panel and a large solar panel can also be used with it. Originally designed for hmmwv and fits in the battery box perfectly in place of the first aid kit. I just moved mine under the commander's seat into the base.
I bought off epay reasonable and got the one with the bag of hardware, 12 & 24v circuit breakers, & tube of dielectric grease. 24V circuit breakers are easy to id as they are reset buttons and the color of the button is the amperage.
On the hunt for the solar panel but rarely see those listed separately.
4 bolts, tap the 2 batteries, and negative terminal. Easy and gives If I remember 6 fused 24v taps and 4 12v taps. I installed a radio grommet in the side of the battery box to run the cables. I already had a grommet for the radios so I used that to run the battery tester cable up to mount horizontal on my Radio tray under a vic3 crew box. The inside of the fuse box has a red flashing led to let you know the battery desulfating board is working. It pulses with or without the solar panel.
Cool stuff that cost uncle a few dimes.
http://www.pulsetech.net/PCMDS-PulseTech-Pulse-Charge-Monitor-Distribution-System-7377.aspx
