- 1,123
- 2,134
- 113
- Wauchula, FL
I personally don't recommend the balancing powder, from my own experience with it in my RV tires. The previous owner put that stuff in the tires and I was unaware of it until the family was on a cross country road trip as a responsible person I would check tire pressure every other day or so and i keep getting slow leaks from the valve stem for some reason. Finally had a slow leak turn into a fast leak and caused a blow out. While getting the tires changed found all the small powder inside that was causing the valve stem to stick open. So as you are driving small particles get trapped in the valve stem then when you check tire pressure a small amount of air escapes pushing the small particles to get lodged in the valve stem causing the leaks. In best case scenario the vehicle is stopped and the particles settle to the bottom away from the stem but thats not always the case.
I can only imagine the problems it would cause to the CTIS when exhausting air from the tires. Especial while rolling at slow speeds and the particles are moving around inside the tire.
