M1008 Build
DIVE DIVE
778
Chesapeake, VA
I finally got the rear end set up this weekend. Did some more painting and prep for the rear axle. Got most things at least primered and now just need to find a place to turn the brake drums then the rear axle will be ready to go back in!
DIVE DIVE
778
Chesapeake, VA
Here are some pics of the rear differential pinion seal and the wheel hub seals. Last pic is of the small 1/2” drive extension that I was using to set the pinion pre-load. It didn’t make it. Got her dialed in though, with running torque right at about 10 in-lbs. I’m now down one cheap (apparently) extension, though.
DIVE DIVE
778
Chesapeake, VA
I was able to find some plastic pads for the leaf springs here locally. They are not identical, but they are very close. I had to trim them up a bit for clearance. Total for all twelve was $10.18. Way cheaper then the stuff I was finding online.
beltfedonly
Wilson/NC
Dive, I have a set of the wheel spacers that you will need to use the hmmwv wheels. They are the new aluminum spacers with the lug nuts.
$100 plus shipping. White Owl Motors in Kinston NC did have a number of the 6.2 pulled from hmmwvs at one time.
DIVE DIVE
778
Chesapeake, VA
I've got a set of spacers already and I'll keep that place in mind if I can't find a motor in the next few months, thanks!
20,709
White Owl is "good people".
Not quite as old as dirt, but they have been in the business for a long time. Lots of knowledge and willing to share. Especially on older green hardware...
DIVE DIVE
778
Chesapeake, VA
The picture of the brakes appears that the wheel cylinder has no contact with the brake shoes. Are they there in place? I can't see them in the picture. Just asking. View attachment 862877
That’s a good eye! I was still working there…lots of parts missing still.
DIVE DIVE
778
Chesapeake, VA
Got the brakes finalized today. Realized that someone had installed the passenger side shoes with the thick one in the front contrary to the tech manual so I had to swap the shoes around. Spent hours cleaning these drums up with a wire wheel at 15000 RPM…they came out really good. I’ll be forgoing the endless search for a place that can turn the drums since they cleaned up so good.
DIVE DIVE
778
Chesapeake, VA
Got the drums baked today for the ceramic paint and got them installed temporarily to check things out. Just need to clean up the parking brake cables and mock it up to figure out the shock mounts.
DIVE DIVE
778
Chesapeake, VA
Got the parking brake cables cleaned up and installed, adjusted the pads, and mounted some tires to get the axle sitting back on the ground. Unfortunately the shock mount plan I had isn’t going to work out how I wanted so I’m going to finish up the paint prep and finish painting the axle without shock mounts and figure that out later. Just need to install the axles, but I’ll do that once it’s painted and under the truck since it’s easier to roll around without them installed.
