tim292stro
- 39
- 48
- S.F. Bay Area/California
The tacos were good so you can't have them back (I'm not sure you'd want them at this point ).
Yes that is partially the type of "confusion" I would have expected. As for the charge stabilizing, you are also not beating it with variable loads like winch and inverter use, or leaving lights or wipers on for extended periods are you (like your daughter might do in the field)? I'd expect that to have a similar effect over time, load disturbances should trigger oscillation in that setup.
Did you happen to measure output currents from each alternator while it was charging? If I'm reading your numbers right the Gnd-12V battery was the one reading 15.3V right (or was it the 12V-24V battery)?
