M146 RV Conversion
LowTech
162
Arizona
Very Nice! [thumbzup]
Is that a leveling gauge on your landing gear? I have some on the shelter that are missing the indicater, wonder if I can replace the missing parts.
RAYZER
59
sanford/florida
Thank you! Yes, it's a leveling gauge, there's one on the front of the gear too.
They are inexpensive plastic ones from camping world.
Jakelc15
37
Hanover Pa
That's a good idea, I'm going to have to go get a couple of those. I just freed up the rear leveling jacks on my trailer. Works better than backing up on wood blocks to try to level it.
RAYZER
59
sanford/florida
You have rear leveling jacks on your m348?
None on mine but I can side level by pulling the pin on the landing gear cross bar, the rear suspension will twist to follow.
I would like to find an electric 12v motor conversation that would adapt to the gearbox on the landing gear (the one on my trailer is civi commercial),
Once I crank down to take some weight off the 5th wheel and pull out from underneath,
I have no less than 100 cranks of the handle in low gear to get to level.
Jakelc15
37
Hanover Pa
Yep, rear legs fold up. They are acme screws. They have a plate that goes on the bottom, kinda looks like a hand tamper.
When I unhook my trailer the front landing gear isn't even touching the ground. I leave them about 2"-4" up depending on how unlevel it is. Not as much cranking. That's what the ramps are for!
RAYZER
59
sanford/florida
That's awesome and you could pull a support trailer behind as well!
I have a Teflon disk on my trailer fifth wheel plate (no grease needed), using the ramps tends to tear it up.
LowTech
162
Arizona
You don't have the stock landing gear on your trailer? Did I miss that somewhere over the course of the build?
Did you change them because the stock ones were bad, or missing?
RAYZER
59
sanford/florida
Yep, back around post 260.
When i bought the trailer it was missing r side landing gear, i tried to find an original to replace it with but to no avail, so had to find a civi set, they work quite well.
Jakelc15
37
Hanover Pa
I was just looking for one of those Teflon plates. The grease gets really dirty when bobtailing. Kinda ironic that you posted about it!
Tow4
663
Orlando, FL
Ray, you are going to need a bigger trailer. You pretty much have that one filled up inside and out!
