M35A2 injection pump install
flatheadvff
12
Myra/Texas
I wouldn't modify the plastic box, as the original military style batteries are available at your popular professional parts stores (ie; o'reilly's, napa, carquest, not your Walmart of parts stores, ie; auto zone, pep boys, etc.). The original style batteries are not much more expensive (10-15 dollar a piece), but have more power and more reserve, even if the spec sheets don't say so. Group 31 batteries are good batteries, but the originals have lasted a year or two, sometimes up to four, longer then the group 31. This has been my experience at my vfd.
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
That fitting under the air compressor supplys oil to you IP. DO NOT ron the truck if you don't have an oil line to your IP.
Caseymikl
Fort piece Florida
Wasn't getting fuel because the fuel shut off was stuck under the cap. Took cap off and sprayed some carb cleaner and loosened anything up that might have been causing it to stick. Works fine now
GrizzlyEater
Milaca Minnesota
Way to go Casey! Glad to hear she's up and running! These trucks are so fun to have. I can't express how useful this site truly is, from the TM's to first hand advice. Thanks for all your photos, good luck and have fun with her.
