MV Addiction filled. Reis the Beast M1078A0 is born
M1078MAN
895
SW Va, Roanoke County
/MAIL CALL\
Recd my 3 SS recommended parts via MRO. anybody need the 3 part kit w an extra 14121. I am leaning towards the 23 part kit due to rust and additional damaged seals PM ME IF INTERESTED [sold]
63 PAOZZ 0PFG7 14121 .RETAINER,PACKING................... .....1 recd 2
60 PAOZZ 0PFG7 202613 .BUMPER,NONMETALLIC................. 1
NI .......... 0PFG7 17429 SEAL.............................................2..........5330-01-300-1323
I also snapped a few pics of the shelter, looks rough, but i think it will be a good fit for RtB
M1078MAN
895
oh yeah she will get the full gamut ..my next step is checking walls floors and ceilings for de-lamination or water damage. Removing the not needed stuff and getting the RTBS bed prepped..
M1078MAN
895
Today was spent washing/pressure wash the exterior of the shelter. Pleasantly surprised, the exo is in remarkably good shape. with one quarter size hole in the left side and two previous improper steel plate repairs that will need to be redone.
I may have got lucky..
Sunday will be spent cleaning and removing interior stuff
Another Ahab
4,903
Alexandria, VA
Trying to figure out the structure of the box:
- So, it's steel plate (like 3/16"?), with reinforced corners and edges throughout, is that how it's made?
M1078MAN
895
Aluminum ext/int plate with a sandwich core of some type of poly foam and key reinforced structural plate aluminum and i believe steel d-ring corners. I will take some close up pictures in a few minutes
The problem comes in if there is leaks and or de-lamination, the structure would require significant repair and or disposal.
Looks like i have made it through the first level of inspection. when i start removing some of the interior stuff, this will give me i better 2nd level condition.
buying theses things is a crap shoot, specifically one as old as this..[60's, early 70's era ]
Another Ahab
4,903
Alexandria, VA
Wondered where the rigidity came from (you know, without a structural frame).
Any idea how thick the wall panels are (like 3/4")?
And sometimes it pays to shoot craps, they're a nice item, right?!
M1078MAN
895
wall panels about 14 gauge, it has a frame structure, stud like..you should see it in the following pics.
shelter close up (4).jpgshelter close up (1).jpgshelter close up (2).jpgshelter close up (3).jpg
Looking for unit info. 3884 c/ci
M1078MAN
895
Not much action on RTB,
Today will be spent pulling the shelter off the trailer, inspecting the under side and contemplate a way to get the shelter in the truck with just a winch and some 4x4,s, no crane or wrecker.
Thinking a bridge of sorts
M1078MAN
895
Be safe my friend
Oh yes, I will.
Great thing, is i have a natural loading dock in my back yard, the truck bed should sit about 3 foot lower, so angle of approach should be diminished to less then 5%, distance from berm to truck, about 4 foot, so all said and done with some poly 2 inch x 4 ft rollers, i should be able to push it across the bridge by hand, but will be using a remote control winch,
bridge support and human clearance are number 1.
I will snap some pics when i get to it..got to get the bed prepped first
M1078MAN
895
Could you have picked a hotter day? I'd be happy to roll down and lend a hand.
Thats no joke, i bet its hot enough to fry ice cubes..off load and inspection went smooth..i am impressed with underside of this unit, probably a direct result of gp not having a fork lift;). here she lies..
and Reis even lends a hand:D
PVC pipe makes a great roller
Exactly what am planning to do
M1078MAN
895
In my quest to find a more inclusive kit for this pump, i stumbled on this part number which contains numerous matching part numbers for the 64574/58477 pump including the 3 SS recommended parts. 14121/17429/202613
-Items with * come in kit,
-items in Italic/underlined match part number of 64574/58477 and TM
-Items Bold,Italic/underlined, are the SS recommended parts
I was trying to find additional parts in a kit form verse buying separate. This gives you 23 parts included in the kit that are a direct part number match for the FMTV pump and 8 parts you may not us..again, price might dictate. 136.75 is what the kit goes for.
Considering the 3 SS parts alone are 60 dollars, for double that you get 20 additional parts.
This below list is the breakdown of a pump with similar features [100190,100195] https://www.spxflow.com/en/assets/pdf/100375_parts.pdf
Note-I also see a regulator and oilier made for the pump in the parts illustration.
I did another review to the TM, and found more part number matches
1 36497 1 Check Valve Body
2 *251215 1 O-ring (1.494 X 1.212 X .141)
3 10002 1 Cap Screw (1/4-20 X 3/8 Lg.)
4 *10442 2 Copper Washer (3/8 X 1/4 X 1/32)
5 *10445 1 Compression Spring(.164 O.D. X 23/32 Lg.)
6 *10423 2 Steel Ball (9/32 dia.)
7 10427 1 Pipe Plug (1/8 NPTF)
8 50494 1 Pump Body
9 202568 1 Ball Guide
10 *10261 1 Copper Washer (3/4 X 19/32 X 1/32)
11 36822 1 Filter Adapter (Torque to 35/40ft. lbs. oiled)
12 27680 1 Filter
13 28400 1 Piston
14 *10263 1 Copper Washer (1” X 49/64 X 1/32)
15 33959 1 Cylinder (Torque to 90/100ft. lbs. oiled)
SS 16 *14121 1 U-cup (11/16 X 7/16 X 1/4)
17 202624 1 Retainer
18 *11034 1 Retaining Ring
19 *28979 1 Gasket
20 *13938 1 Compression Spring(1-3/16" I.D. X 5” Lg.)
21 28395 1 Spring Guide
22 *12692 1 Spring (3/16 O.D. X 1-1/2" Lg.)
23 *10303 1 O-ring (7/8 X 3/4 X 1/16)24 338
24 33824 1 Piston Body
25 *14265 2 Piston Ring
26 *28239 1 Gasket
27 37468 1 Rear Head
28 10241 3 Lockwasher
29 11434 5 Soc. Hd. Cap Screw(#10-24 X 1/2 Lg.;Torque to 50/55 in. lbs.)
30 33822 1 Piston End Plate
31 *28183 1 Piston Poppet
32 33845 1 Exhaust Valve Stem
33 *251835 2 O-ring (2-1/2" X 2-5/16" X 3/32; Nitrile)
34 *10300 1 O-ring (5/8 X .468 X .07
35 *251214 1 O-ring (1.002 X .720 X .141)
36 16450 1 Steel Washer
37 16453 1 Screw (#10-24 X 4” Lg.;Apply Loctite 277 or equivalent to external threads.)
38 *205674 1 Cap Screw (#8-32 UNC X 3/8 Lg.)
39 *205679 1 Spring (.485 O.D. X .915 Lg.)
40 *11863 4 Backup Washer(1/2 X 3/8 X 1/16)
42 28387 1 Muffler
43 *34283 1 Gasket
44 21094 2 Bushing
45 *10268 4 O-ring (1/2 X 3/8 X 1/16)
46 *16448 1 Compression Spring(5/16 O.D. X 13/16 Lg.)
47 *12522 1 Disogren O-ring(3/8 X 1/4 X 1/16)
48 *12549 2 O-ring (13/16 X 3/4 X 1/16)
49 15426 1 Drain Tube
50 *10275 1 O-ring (15/16 X 3/4 X 3/32)
51 10807 1 Cap Screw (1/4-20 X 1/2 Lg.)
52 50888 1 Port Blockg
53 14456 6 Screw (Torque to 25/30 in. lbs.)
54 *29992 1 Foam Tube
55 *33853 1 Reservoir Gasket
SS 56 *202613 1 Bumper
57 41633 1 Reservoir
58 15823 4 Lockwasher
SS 59 *17429 1 Backup Washer(2-15/16" X 2-3/4" X .045)
60 37434 1 Air Cylinder (Locate Groove toward top near cover plate.)
61 11151 4 Soc. Hd. Cap Screw(#10-24 X 1-1/4" Lg.)
62 24132 1 Filler Plug
63 50889WH2 1 Cover Plate
64 17428 4 Soc. Hd. Cap Screw(1/4-20 X 4” Lg.
-Torque to 90/100 in. lbs. oiled.NOTE: Cross torque in increments of 50 in. lbs.)
Part numbers marked with an asterisk (*) are contained in Repair Kit No. 300140
I also posted this to the "everything pump related thread"
Well found this 23 part kit from mro for 79.00 free shipping. ordered
