Official 2013 Georgia Rally Buy/Sell/Trade/Giveaway Thread
wilfreeman
Richburg, SC
I've got a mirror arm and brackets.
Thanks Adam - I'll check back with you before the rally.
I looked a couple hours ago and I am afraid I had forgotten my spare went on TMNT's deuce.
Thanks anyway Clinto! BTW, I don't need the air filter gauge - I was able to tighten mine up.
I will bring some straps and pull the low-air buzzer out of that cab I just dismantled.
Thanks pctrans - I'll write it down and check back with you before the rally.
mdmorganwife
15
Forsyth Ga
Here is a few things we will have up for sale. I am sure we will come across more stuff . I have ALOT of Mrap fan belts for the CAT motor that will be FREE to anyone that wants them. Also will have parts out of our M129 trailer for sale, such as lights and window frames..
Air/water tight fiberglass cases-$20each
Dehumidifires-$20 each
Medium towbar with pins-$600
2 snatch blocks-$65 each or both for $120
5ton (939 seires) windshield frame with glass-$100
Drz offroad set up (dirtbike tires and wheels)-$500------SOLD
The following items for sale need to have a buyer before the rally for me to bring them because of their size:
2 sets of 5ton axles (one front, one rear=set)- $1000 each set or $900 for the front and $250 for the rear
Two pulley heavy duty snatch block-$50
939 series hood (includes lights and latches)-$250
1987 Jeep rebuilt tranny (like 5 miles on it)-$200
mdmorganwife
15
Forsyth Ga
What size are your dehumidifiers and do the buckets come with them?
Not sure on the size but here is the NSN info on them. They do come with the drain buckets. For the $20 I have plugged them in and seen that they work. May need alittle cleaning. But if I go through them (clean and paint) I will be charging $40. THe pic is when we were going through them and the buckets are in the background
FLOOR TYPE,MOVABLE,SHALL BE CAPABLE OF CONDENSING A MIN OF 40.0 PT OF WATER DAILY AT 80.0 DEG F WITH 60% RELATIVE HUMIDITY (ANSI STD B149.1); 22.500 IN. H,12.750 IN. W,18.000 IN. D; 115.0 VAC,60.0 HZ,SINGLE PHASE COMPRESSOR MOTOR; AUTOMATIC HUMIDISTAT; OFF-CONTINOUS RUN CONTROL SWITCH; AUTOMATIC OVERFLOW CONTROL W/INDICATOR LIGHT; MOISTURE CONTAINER SHALL HAVE A MIN CAP. OF 8.0 QT
3dAngus
101
Perry, Ga.
Those things (dehumidifiers) are fantastic, and will suck the water out of a concrete floor. If you don't run an air conditioner in your shop these things are a necessity to keep your tools from rusting up. I still use mine and sold about 30 at last years Rally.
They only run in summer time, or when temperatures are at 55 degrees or more inside the shop, but you don't usually need to dehumidify in the winter anyway. I highly recommend them. And if she has the buckets, that's a big plus. I fill mine up with water every 24 hours. It's crazy how much water gets in the air in the garage.
A friend of mine was selling these on craigslist for $45, so you can buy at that price and resell and double your money. Fantastic price. Thanks Mahala! Good offering.
3dAngus
101
Perry, Ga.
Hey! Come to think of it, save me two. I have a half dozen, but at that price, I cannot afford to refuse them. Thanks for the offering.
wilfreeman
Richburg, SC
Yeah, I bought one for the basement and piped it outside - still running and keeping the 900sf area @ 60%rh year round! I'll take 3 Mahala, and my brother wants 2, so put us down for 5 if that's not being too greedy!
ODDBALL007
GENEVA FLORIDA
Ill take 2 uncleaned
