Official 2013 Georgia Rally Buy/Sell/Trade/Giveaway Thread
3rdaavbn
Suwanee/Georgia
11- ndt 9.00x 20 on Deuce rims. All hold air well, some 50% Some 85% one is new. $35-50 ea. NOS starters for multifuel and 5 Tons $ 200.00. used starter $ 75. NOS Hummer spring seat set $325.00. Deuce compressor $ 50. Deuce cab soft top frame and bows.
EMD567
Driver for the Ga Mafia
Aiken SC
Mahala,
939 series won't work in a 800 series. Sorry about that.
Recovery- thanks for looking for the M37 TM's
timntrucks
146
Ponchatoula LA
i am in need to some lug nuts. the ones like on the front of a 5ton.. i singled out my 818 and dont have enought large lug nuts
1,827
My list of TMs
Trailers
ORD9 SNL G750 M127 Trailers. April 1953
TM 9-2330-213-14&P M103A3 M105A2 Oct 90 (Binder)
TM 9-2330-205-14&P M200
Trucks
M715
TM 9-2320-244-34P Depot Parts M715 Nov 71
M880
TM 9-2320-266-10 Operators Manual Jan 76 (2 copies)
M35/M35A2
TM 9-2320-361-10 Operators Manual Jan 88
TM 9-2320-361-20 Unit Maintenance Oct 91 (binder)
TM 9-2320-361-34 Depot Maintenance May 92 (binder)
TM 9-2320-209-20 Unit Maintenance April 65 (3 ring binder)*
TM 9-2320-215-24P Organizational Allowances M602 (Modified M35) Aug 58
TM 9-2320-209-20-2-1 Unit Maintenance May 81 (binder)
TM 9-2320-209-34-2-3 Depot Maintenance May 81 (binder)
TM 9-2320-209-34P Depot Parts Dec 76 (binder)
TM 9-8022 Dec 54
OP-CR53 Austin Western Manual for the M108 and M62 June 53
General Manuals
TM 5-725 Rigging Oct 68
TM 9-8000 Automotive Principles Oct 85 (binder)
TM 43-0001-31 Tacom Data Sheets June 85 (new in plastic, 2 copies. These have 2 page data sheets on most wheeled vehicles and trucks)
TM 10-7200-200-13 Jerry Can Manual Feb 74
TM 10-8340-211-13 GM Tents Feb 90
TM 11-5830-340-12 Reprint VIC-1
FMs
FM 21-305 Manual for the Wheeled Driver
FM 21-26 Map Reading and Land Navigation
FM 10-16 Tent and Canvas Repair
FM 5-36 Route Recon and Classification (Think Bridgeplates) May 85
FM 55-65 Preparation for Overseas Movement Jan 76
FM 20-22 Recovery and Field Expedients July 70
FM 20-22 Recovery and Field Expedients Aug 84
FM 20-22 Recovery and Field Expedients Sept 90
I have several manuals dealing with gas gensets as well. These will likely be sold as one lot
* These are the 1965 manuals which cover some gasser stuff as well. I regard them as my favorites.
Blake
72
Opp, Alabama
For sale items at Georgia rally:
-camouflage net (the sets or the diamond and octagon by themselves)
200.00 per set or 125.00 per net by themselves
-complete m101 backing plates (take off/ old style)
25.00 a piece
-completed m101 front hitch assemble (take off/ old style/ Lunette, chains/hooks, landing leg...)
100.00 Obo
-passenger window out of m35a2 (bottom track slightly bent)
20.00
-new style multi fuel head gasket (1)
make offer
-old style multi fuel head gasket (1)
make offer
-multi fuel valve cover gaskets
make offer
-rt-524 (24087 color and clean; complete internally)
400.00
-prc-77 very nice condition, complete, with canvas pack, and am-2060 power supply
600.00
if you have a radio rig at the rally, you are welcome to test them onsite.
-miscellaneous cucv blaxer, m37 and m151a2 parts, pm me for exact wants and I will see if I have it
-2 sections of temper tent frame (16x20 total) with end curtains (green), floors, rain fly with stanchons, and extra main tent sections (tan). Some of the round pieces that go side to side need repair to the lock levers but useable as-is
500.00 for all
-m151a2 emissions gas tank (take out)
40.00
-cucv tow shackles (missing pins)
10.00
-alice packs, duffle bags, and other miscellaneous bags, some foreign
-usmc lifting arms that hook above rear axles and come through loop on side of bed (not sure exact model it fits)
-military coleman lanterns, complete but need repair
-military coleman lantern parts
-cucv th400 and transfer case (take out/untested)
-dash section and left front fender unit cut out of a m151a2 tub
-tent pot belly stove
-tent stovepipe heat shields
-tent stovepipe spark arrestors
-woodland bdu's med long-extra large. Most large long
-flight suits nomex large long type sizes
-very heavy snatch block with a loop on the end. Probably 5 ton size. 10" diameter?
-cucv blazer rear tailgate glass
-cucv blazer rear side glass (have to check which side)
Pics available on request. PM me for details
what I am looking for:
New/nos g749/m211 gmc parts
gmc exhaust system parts (new or used)
Thank you!
mdmorganwife
15
Forsyth Ga
I'll take two dehumidifiers as is thanks. Sent PM
Stationjj
Gotcha down.[thumbzup]
We only have 5 dehimidifiers left. We also have 8 that would be great for parts for $10 each. Two of them have the cord cut so we couldn't even try to see if they worked and the other 6 produced very little water if any. May just need to be taking apart and cleaned.
3dAngus
102
Perry, Ga.
Mahala, if you and Daniel cut those bad ones up, and separate the copper, aluminum, and compressor, you get $8 in scrap value from the scrapper across from the Base on Hwy 247. Not producing water might mean the compressor is low on Freon and not running properly. You can hear it vibrate when you power it up if it comes on at all, above 55 degrees farenheit.
I found a sledge hammer works better then a screwdriver if you want to scrap them and tear off the plastic covers real quick. Makes a mess though.
3dAngus
102
Perry, Ga.
I need a roll of field wire for my TA-312s. Someone had a ton of it, but cannot remember (Mike?).
Please PM me cost if you have a clean new and small roll of WD1 wire. It is black in color and cheap steel wire for the phones.
mdmorganwife
15
Forsyth Ga
I would have thought that they looked to much like AC units to scrap.
goldneagle
1,509
Slidell, LA
You guys do know it is a federal offense to purposely release freon into the atmosphere. You are supposed to recover any freon before scraping the unit. That is why they rather sell the units than scrap them. Less labor expense in recovering the freon. GRAINGER had to pay a contractor to recover the freon in the defective dehumidifiers and A/C units before they could trash them.
SCSG-G4
PSVB 3003
5,400
3,494
Lexington, South Carolina
But I've only got 34 miles! How long of a piece do you need? Actually, each conductor has four steel wires and three copper ones in it.
