Project Wild Weasel M1009
cucvrus
10,505
Jonestown Pennsylvania
I was out working on the Wild Weasel yesterday. I removed the fuel tank and that in itself was an adventure. The Army had it out at one time and replaced the sending unit. One of the strap bolts was snapped off and the bolt was replaced with a 3/8" bolt, The hoses were way long, and the filler neck was barely into the fill hose. It still had the factory clamps on it, and you know you can't reuse that type of clamp. They just jammed the hose into the clamps. I can't attach pictures because this site is now not recognizing my iphone. More later. I have the tank out and am going to pressure wash the entire underside. I will take pictures and post when the system accepts them.
cucvrus
10,505
Time to run the pressure washer. One of them love hate jobs. Prepare to get wet and the shower and change clothing. So plan and do it right the first time. You will get wet. Wear work clothes and safety glasses. Prepare to get soaked. Try not to but you know.
cucvrus
10,505
I violated one of my own major rules. Never let anyone use your equipment. NEVER. I went to use the pressure washer after waiting for a week to get it back. It was dropped off when I was mowing and today I went to use it and you know. It is not a cheapo store bought model. I guess that is why they have repair shops. It is possible that it failed thru no one’s fault but why does it always seem to be this way.
WWRD99
1,939
York Pa
I'll go pressure wash someone's stuff before I loan one out again! What most people don't know is if you leave the engine running without using the water it gets very hot then burns up the pump or the release valve will pop...this is a 13 horse honda with a 5k 5 gallon with a burned up pump!! 700$ pump...ugh. motors still good at least.
Sent from my SM-S906U using Tapatalk
cucvrus
10,505
Oh yea I see the light switch nut and the horn inner contact ring. Still not fooled because you laid it out on OD green canvas. Born at night but not last night. And did you say 5 gallon fuel tank on the Honda. Not seeing that.
WWRD99
1,939
York Pa
That's not od green canvass!! That's the table we used to paint the hood on..got sprayed too. The honda is a 5 gallon per minute 5k psi pump...I think the honda has a 3 gallon tank. That is a switch for a cucv too...took it out of the cab out back. That pump setup weighs just at 140 lbs. It's a big pressure washer.
rtk
454
Lockport N.Y.
Rick , I have been there myself a few times !!! The bad part is nobody mentions that when they drop it off !!!! As my father used to say NO good Deed goes unpunished !!!! stay safe , be well , and don't let it get you down !!!!
cucvrus
10,505
I spent the last 3 hours pressure washing until I am soaked and the M1009 is about as clean as I can get it with a pressure washer. I have seen better M1009”s but this one is a lot better then most I seen . I will apply some Rus fre coating on the underside or some water based coating. More than likely the water based black coating I have. It cleans up easily and I don’t need to wash in mineral spirits. That chemical coating gets old real fast and cost a lot of money to MM work with. Soap and water work easy and are inexpensive.
IMG_1954.jpeg IMG_1952.jpeg IMG_1949.jpeg IMG_1950.jpeg IMG_1948.jpegIMG_1947.jpegIMG_1946.jpeg I guess I will go push mow some lawn to get dried off. I feel like I was in a sand box. Like at Ft. Knox at 4AM on the sand pit and horizontal bars all before breakfast. Have a Great Day.
FarmingSmallKubota
1,394
Wapakoneta, Ohio
Pump is easy to rebuild a couple of youtube videos made it easy to do mine
WWRD99
1,939
York Pa
If the 2 bolts that hold the reducer and input didn't break off inside the pump housing, I could have rebuilt it for under 50$.
