PTO help
Hooty481
Russell County Kentucky
The morgan model 40 is originally a fassi f40. Morgan Crane company modified the crane as they do with all of their cranes. I was modified by adding a hydraulic winch, removing the down riggers and designing a new mounting plate so it would mount to a ship.
tobyS
840
IN
Hooty, perhaps you can start another thread and add some pictures of the crane and your truck??
gringeltaube
Staff Member
2,682
Montevideo/Uruguay
Possible responses: Same as engine and transmission output... or: PTO is directly coupled to the rear of the TC-input shaft... or: standing behind the truck and looking at the PTO output flange, it will turn CCW, for all forward gears....
G.
m16ty
223
Dickson,TN
That's what I was looking for. So I will need to order a cw (clockwise) pump.?!?
Yes.
If you happen to run across one that is CCW you can usually take them apart, swap some parts around, and convert it to CW rotation.
M-1028
Sealy, Tx
Still looking for info on the pto yoke bolt patern.
What do you mean bolt pattern? Yoke sit's on a 1.25", single keyed shaft, pretty common for pto stuff. Or are you talking about the bolt pattern of the pto itself? If that's the case just measure the cover on your t case.
ODdave
41
lansing michigan
Patern is the same as m211/m135 and some of the jeep drive shafts. I used a jeep shaft for my pto. What size u-joint do you want? I probably have a flange.
Hooty481
I'm not sure on what size u joint. The drive shaft will not connect directly to my pump. My pump will be connected with a love joy the to another shaft with a carrier bearing and then a drive shaft. If that makes any sense
m16ty
223
Dickson,TN
I've seen different outputs on the t-case PTOs. Flange, yoke, and sprocket.
Mine has a flange and what I did is make a adapter. I measured the bolt pattern (don't recall the measurements), drilled out a mating flange, and welded it to a u-joint I picked up at NAPA.
I'm not sure why you're having to add a carrier and a lovejoy to the driveline. Can you not run a simple driveshaft like mine?
