Ronmar
- 8,406
- 113
- Port angeles wa
Plate, and put the turbo in a fabric cover. Probably a good idea for a rock shield on the outside since it is on the outside of the frame…
Ok. I could put a box around the bottom and 3 sides of the filter easily with bolts into the mountPlate, and put the turbo in a fabric cover. Probably a good idea for a rock shield on the outside since it is on the outside of the frame…
Initially. Followed shortly by losing the whole truck...... It's like tripping on your shoelaces that have come untied and falling...... into a pond full of gators and syringes.Did he just lose his u-joint?
It's the digital, visual representation of pumping bits of C4 into the HEUI pump.Initially. Followed shortly by losing the whole truck...... It's like tripping on your shoelaces that have come untied and falling...... into a pond full of gators and syringes.
One cut with a chop saw and the studs will come out. I literally just did this last weekTomorrow I’ll solve this puzzle one way or another.
What's the grease spec for those? Red, Blue, pride colors?Went ahead and pulled the left rear. Inner bearing packed thank goodness. Isn't that odd?
Just dropped the right side hub and bearing in parts cleaner to soak a bit before cleaning up for inspection; the left side looks good. Headed into town for some scotchbrite pads and such to see where we get on the right spindle—
Yellow!!? Yellow's a medical condition, not a grease color. Is there a civilian equivalent?GAA. Grease, Automotive and Artillery.
It's Yellow. It's grease.
Ultimately it's just wheel bearing grease. I used Amsoil blue waterproof grease on all the trucks I've done hub services and ECO hubs on. No issues at all.Yellow!!? Yellow's a medical condition, not a grease color. Is there a civilian equivalent?
Probably same as Cat NLGI #2 GC-LB blue utility grease. I have that in the 5gallon pump setup. Any issues you see with the Lithium type?Ultimately it's just wheel bearing grease. I used Amsoil blue waterproof grease on all the trucks I've done hub services and ECO hubs on. No issues at all.
I suppose the military likes the yellow because you can tell when it's dirty and some soldier needs "remedial training"
