phil2968
- 17
- 38
- Lakeland, Florida
I should be home at a decent hour today and if the rain holds off I'll see if I can take a pic of it.
Anyone have any pictures of the new style starter bracket installed on truck where does it mount?
OH how funny doghead , yes I did that made me laugh. It was painful but I looked at -20No, not the tm.....
I contacted Lock-N-Stitch about my block and their reply was to remove the engine and braze on a new ear and redrill the hole.There is a company called Lock-N-Stitch their specalty is repairing cast iron. They make kits you can buy for do it your self cast iron repair
Denny
I contacted them too and sent pictures but got no reply , haha , I discovered the other hole is elongated and the flywheel is worn bad from grinding , I'm wondering if it would b more cost effective just to find a good engine , I'm not sure the problem wouldnt resurface again if by some miricale I was able to perform the repair correctly and get every thing centered correctly - input welcomeI contacted Lock-N-Stitch about my block and their reply was to remove the engine and braze on a new ear and redrill the hole.
How big of a problem is the water pumping in a different direction ?The ip is almost identical. The Hmmwv uses a 24v shutoff. The Cucv is 12v. Just the cover needs to be changed out.
