donquijote
- 36
- 28
- Louisiana
We had some decent snow in B.R. Juan for a short period.
Sent from my SM-N950U using Tapatalk
![](http://uploads.tapatalk-cdn.com/20180117/e8df63c5c0a039f1ed25ec95218a1f86.jpg)
Are you sure you got the right pic? That looks like Canada not LaWe had some decent snow in B.R. Juan for a short period.![]()
Juan, Very nice!Fellow Member Linhster graciously made me a deal on some comm gear that was still on his truck. Thanks for working with me!One of the items was a complete Harris RF-382 Fast antenna coupler with shock mount, mounting plate, cable cover and cables
Juan,Installed the roadside (driver's) antenna tower and upper & lower reinforcement plates. Takes lots of 1/4 screws....
Part numbers and pics of install. Busy area under the fender with fording exhaust brace, seat belt brace and antenna reinforcement but it all fits.
I did not install an antenna yet as I wanted to keep the cover on for now until I finish some other projects. Tower fits fine under cover.
Besides looks, I also like this hunk of metal behind the seat. I know it is not a roll bar or anything close to it but a lot sturdier/beefier than the c pillar. I hope to never test.
I do have a large multi pin connector cable that came with it for the control. Not sure on Power? Is the ceramic cone with a stud/nut the power?Gotta say for that RF-382... I do have a radio that's fully-functional that can hook up to that and run it through to full rigors to see what does and doesn't work. If we ever are going to cross paths at some point, I'd be happy to bring along my radio to said meeting place to try it out. Do you have the control cable and power cable for it? I don't have either of those, so that would have to be found before we could make it work.
I actually really want to add an RF-382 to my HMMWV some day, as I do intend to run it as a comm truck in live use, but I can only find those couplers from a Canadian source that has them BNIB, and priced to match. If you ever decide to change your asthetic, please do give me a message.
Cool as they are hard to find. It appears the first ones using the towers were bolted to the fenders bare. I guess some whacking of trees and overhead clearance issues, They issued a bulletin I found in the PS magazine to retrofit plates top and bottom. Plates are easier and cheaper than fender replacements. I found a source for both of the bottoms as the set up I got only had the roadside top plate. Ironically the donor truck had another left tower mounted on the right side, sideways with no plates. I have the correct right tower but can not find the top plate anywhere.Juan,
You have made another post useful to me. My truck was a HQ vehicle with lots of signs of comm equipment having been attached (and dozens of holes drilled in the body, a future problem to address). I didn't realize the tower mounting pates had underside reinforcement (My truck still had the tower mounting plates when I picked it up). After reading your post I ran out to see if my mounting plates had the underside reinforcements and they did. So I'm good to go to put up my towers. Thanx
That would be a real good idea, but my holes are from small self tapping screws they used to tie down cables and one large hole they missed drilled and hit one of the reinforcing angles which they hacked out pretty bad to make the hole work. On the bright side I have always wanted to learn how to TIG weld aluminum. I figured it would be hard to screw up on such a small hole.My fix for empty misc holes is to plug a bolt with washer and nut underneath to make it look like it belongs there![]()
Is that large hole in the back right corner top of fender? Btw, The tm shows a hole for the cabling for the Rf-382 there if so. Don't recognize the other patterns ? and looks like 2 plugs have also been installed in pic 1That would be a real good idea, but my holes are from small self tapping screws they used to tie down cables and one large hole they missed drilled and hit one of the reinforcing angles which they hacked out pretty bad to make the hole work. On the bright side I have always wanted to learn how to TIG weld aluminum. I figured it would be hard to screw up on such a small hole.
have about 6 areas with stuff like this....
View attachment 722645View attachment 722646View attachment 722647
Very interesting stuff thereHere's some related stuff...fender plate looks field made for left side...flip it for right.
inner fender brace...looks factory for right.
Large hole is on the driver side rear. There was a large mounting plate there that I removed and threw in the extra stuff pile. In pic one there are actually 4 plugged holes, and there are a lot more plugged holes nearby. I wasn't sure if they were standard holes that are in every HMMWV and are just plugged with plastic plugs for use if needed or previous drilled holes form applications in a former life. Don't have any trucks close enough to compare what a normal setup looks like and like I have said before I didn't pay too much attention to those type of details (to my dismay these daysIs that large hole in the back right corner top of fender? Btw, The tm shows a hole for the cabling for the Rf-382 there if so. Don't recognize the other patterns ? and looks like 2 plugs have also been installed in pic 1
Whoops, I haven't actually looked at an RF-382 in a while. Power & control is all on the one multi-pin cable, so we should be able to just hook up and test it. I don't have an amplifier, but I can disable my radio's internal coupler and utilize exclusively the RF-382 to see if it at least does something.I do have a large multi pin connector cable that came with it for the control. Not sure on Power? Is the ceramic cone with a stud/nut the power?
Ironically , I think I will be up your way in Sept for my Niece's wedding. She dances Ballet at a company in Indy but I doubt I will have my toy with me
I would be glad to get our gizmos together down the trail....sometime
