5 ton lockout hubs
jatonka
Is any one out there familiar with the workings of the air actuated sprag in the 5 ton? I have one apart at my shop and I can't see where there is a neutral position where the sprag collar would lay when there is no air to the cylinder. I think the sprag defaults to forward direction when the transmission is in any forward gear and is set to reverse when the reverse gear rail actuates the valve on the transmission and puts air to the air cylinder on the transfer case. If I didn't have these reservations about the ability of the sprag to really lay in neutral, I would already be selling the 5 ton lockout hubs. I understand that some of you just shut the air off to the air cylinder and call it good, my concern is that it does not really put the sprag in neutral or free wheel. Someone wanna explain where I am missing the actual working of this 5 ton transfer case? JT
area52
maybe try cutting the air off to it and get in a spot to try engage it to see if it does engage?
wehring
hubs
I have an airshift t-case in my 5 ton. I am in Adam. Ring my cell when they are available.
Justin Wehring
979 997 3112
All the 5 tons nomatter what series they are are 2 1/8" 16 spline. The only different ones were the axles that ame in the Oshkosh firetrucks they had 2 1/4" 23 spline shafts but these are rare.
I would be in also. I believe 2.5 ton lockout hubs are like $500? so somewhere along those lines would work for me.
Being that the size is twice that of a 2.5 ton it'll be more than $500 but they won't be no $2400 a pair like those goofs at Spare Parts Inc. I talked to Mitchell there and he's a bit high up on his horse and doesn't care if people buy his stuff or not. So oh well Russ can make them alot cheaper than that.
Squirt-Truck
Master Chief
Jatonka, THe 5-ton sprag system is spring loaded to the center position. When normally installed there is ALWAYS air on one side or the other. The poppet valves on the shifter rail are simply made that way.
The manual (pp 2-60 of the 211-10) even indicates to open the air drain to allow the sprag to return to netural.
I installed an air cut-off years ago (and thousands of miles) on lil-Squirt and have had no issues.
jatonka
Hi Squirt Truck, I have a 5 ton transfer case apart in my garage, I have the top hat off. I figure that it is in the neutral position as it sits there with no air to it. I will try it tomorrow morning. It ought to turn free as it sits there, right? If that is the case, I will be real happy, and so will a bunch of other people, I haven't done the lockouts for them because I didn't think they would be totally effective. I really appreciate your input. John T
ncduece
I JUST REPLACED MY TRANSFER CASE IN MY M818 i was having problems with it locking the front wheels in forward, made notes about testing it after i put the new xcase in with out air the front wheel off the ground and rotating it by hand it the front wheel will spin in ether direction. with air up and shifter in forward the front wheel will spin forward but not reverse. with air up shifter in reverse the front wheel will spin reverse but not forward.
ncduece
by the way i suggest any one buying a five ton do this test before yo make the purchase. ask me how i know!
Squirt-Truck
Master Chief
ncduece,
Most common failure on the 5-ton failure is in the poppet valves on the shifter rail. Air leaks in the operating cylinder are common also but not killer.
What you identified is the proper way to test the sprag operation.
bigford
I'll take a set if reasonable also.
AVM used to make some years ago for the 2-1/2 and 5 tons. I had a set of the 2-1/2 tons with the air shift t-case. Just left the air off until I went offroad and locked in the hubs.
I hope to have an answer in a couple days for ya on price. He's still doin some figures. Does anyone have a hub they would be willing to send to him for some measureing so he can save some time on the design? He'll conpensate ya for your time and the shipping cost to and from. If so let me know asap.
Thanks
Adam
area52
If you need one, I have my M54A2 just sitting waiting for repairs. I can pull one off and send it out.
BLOWN Z
5 ton lockouts
i would like a set of 5 ton lockouts cost dosent matter call with imfo on lockouts 314 2801442
