From fire truck to MTV
MatthewWBailey
Thanks for this site. My truck runs great now!
1,537
Mesa Colorado
Wasn't a big fan of the split collar that came with the ECO hubs, mine is the one with an M5 screw. Considering if that clamp failed, the entire wheel would detach I started looking at another solution. This got kicked into high gear when I checked for wheel bearing tightness and I had play in both the left mid and rear wheels. All wheel bearings were tightened when ECO hubs were installed and verified "tight".
Here is my solution, an aluminum spacer that just slides in place and holds the stock inner gear in location. No way for the nut to back off now. The three holes are for gear oil to be able to flow freely from inside/outside.
View attachment 912274View attachment 912275View attachment 912276View attachment 912277
Would a heavy spring do the same job without being subject to CTE issues (of a solid spacer) and also accommodate and future wheel bearing adjustment inward?
aw113sgte
975
La Crosse, WI
Yes a spring will likely work just fine too (with the stock gear). That said, finding one would be difficult in this size.
Springs obviously compress so you still have a risk that it could compress enough to release the pin lock. Likely? No but something to be aware of. The CTE mismatch really isn't an issue we just have to give a little bit of clearance between parts. You could always make the spacers out of steel if you want the same CTE. Aluminum is just far easier to work with on machines I have.
MatthewWBailey
1,537
Mesa Colorado
Yeah I was just thinking out loud. Sourcing a spring for that will be long winded. I've used some flat spring washers on my track loader for the track tensioner but those are 3" diameter and take significant tonnage to compress.
Seems like the temp would be less of an issue anyway since the 2:1 reducer is removed. Not much heat being generated there with eco hubs.
aw113sgte
975
La Crosse, WI
Moving forward with an internal frame setup so I don't have any thermal bridges. Unistrut compatible framing from Menards was on sale, 12% off.
Installing and testing the spring compliance setup. Tough to see on the camera but jacking up the box lifts the frame a lot, I'll get the rest installed and test it when crossing up the suspension.
coachgeo
3,466
North of Cincy OH
Since it appears you left a gap about size, maybe little less f M1079 between front of Habitat and rear of cab... would think one could install a rearward skirt width of cab, with fixed top and drop down bottom. extending from cab as far back toward the habitat as can go yet not interfere with cab tilt Flipped down bottom to allow it to lift past fixed passage attached to habitat. Sealed door on cab rear face.
Paired with this; a narrow as possible passage, centrally fixed skirt on habitat; extending toward cab as far forward as possible, yet not interfere with tilting cab. Gangway might be needed to slide out when using passage. Sealed door on front face of habitat.
Idea being with the cab skirt large enough, that as habitat moves about on it's flex mounts.... Habitat's smaller skirt structure would not contact the cab one. The length of both should allow for overlap of cab portion beyond the open end of habitat's skirt structure resulting in an open box (on cab) surrounding a smaller open box (on habitat). Sealed doors block out weather. Nothing needs to connect between the two but the gangway.. and it is only slid out/connected when crawling /sliding thru from one to the other.
Another possible advantage here is the skirt combo should cut out wind drag a good bit compared to just a crawl thru box in center of the gap.
Jbulach
2,210
Sunman Indiana
You might consider getting rid of at least half of the springs/bolts and installing some guides or link arms to keep the box from shifting to the side or front to rear under extreme forces.
aw113sgte
975
La Crosse, WI
Using a link system does have it's place, however I don't see many benefits in this type of box setup.
Max it can shift now is only about 1mm. I'd rather have that level of control than if I do a link system since there's a swing arc and that means I would have to have larger through holes to avoid binding. I may add in some fore / aft locating plates at some point, but I kind of doubt it will be needed or even beneficial with all these through bolts. C channels are 1/8 of an inch thick, so they aren't the most rigid thing in the world and spreading the load among all of them is the strongest solution. Benefit of having this many connection points is in a rollover. The box will help to protect the cab in most accidents. Also considering the weight of the box, I want significant spring force so it is not flopping around like a lot of the expedition habitats you see - safety and control on road is really important to me, off room capability is second to that- it's not like a truck this big is going to be going down very serious trails anyways. Springs were sized for maximum allowable force without deforming the c channel under structure. Also have about 50 mm of spring compression distance.
Jbulach
2,210
Sunman Indiana
How much total compression force will you have at maximum compression at each mount point.
aw113sgte
975
La Crosse, WI
Got to try out the spring setup and results are....great!
Went to the same spot and flexed out the truck as much as I am likely too. Front springs compressed the most, to about 80% of available travel. Tried some "evasive driving" to see if I could get the box to rock but it wouldn't. Still plenty of tire travel, of course that will decrease some with more weight I will add as the box is basically empty right now.
ramdough
1,729
Austin, Texas
If you look at what is typically done on spring mounted campers, there is always a solid bolted connection at either the front or most rear location and a feature that prevents slewing. Usually they are slide plates.
Below are two references:
in fact, in many place it is illegal not to have those features.
If you were to swerve, your whole box could swing to the side and you will get a slide hammer effect, wich may overload your bolts. Also, the slewing action can zipper your bolts, that is why they always have a guide plate. I would seriously consider adjusting your design. What you have is fine for slow, but get moving fast, inertia may not play nice.
aw113sgte
975
La Crosse, WI
View attachment 913450View attachment 913451
I have that first book, it's pretty well done. Yes those plates have their place and I plan to add them in time as an extra safety measure. They are much more important in applications where there are only a couple spring bolts and the tolerances between holes are high. In my setup, I had the advantage of drilling matched holes so at maximum they have .7mm of freeplay. Combined with tolerance stack-up and chassis movement, realistically there is no freeplay currently. Over time, it's possible it will develop free play and I have additional rail space for that addition - just haven't made those yet. Wanted to get the spring setup tuned first.
On mass produced modular cabs this setup would never work as that slide hammer effect would exist as tolerances in the bolt holes would have to be far higher to unsure frame and cab would bolt together.
aw113sgte
975
La Crosse, WI
That's an interesting idea! I haven't ordered the major materials yet so I'll give it some thought.
aw113sgte
975
La Crosse, WI
Been working on habitat prep, doesn't really make for interesting pictures. Will be putting up wood paneling with an unitrut structure on the inside where I can attach all cabinets, beds, etc. Making for a very strong and modular setup.
Took it out on snowy roads for the first time today. Learned a few things.
1. This thing is heavy and doesn't like to stop super well on hills. It will try to swap ends going down hill - got about 30 degrees sideways when rear brakes locked preferentially over fronts. ABS would prevent this (see note below), but then I couldn't get the snow building up in front of the tires.
2. It's more capable on slippery roads than all my neighbors 2wd vehicles that couldn't climb the hills near us.
3. ABS disengages in every mode except HWY on CTIS controller (ABS light blinks). This may be standard but I haven't seen this mentioned before. I did replace the ABS controller so maybe this one is programmed a little different.
4. C7 uses 0.5gal/hr at normal idle, 1.0gal/hr at high idle - per CAT ET
5. C7 warm-up mode with the pac brake doesn't automatically turn off - it will stay on till radiator fand engages
20240101_135817.jpg20240103_121107.jpg20240111_094906.jpg20240111_095355.jpg20240111_094145.jpg
Lostchain
588
Portland, OR
ABS blinking light during different CTIS modes isn’t something mine does. Never heard of that before. I wonder if the ABS is reporting any codes at that time.
aw113sgte
975
La Crosse, WI
Must be due to my ABS module programming. The light stops blinking the second I hit HWY mode on CTIS.
From the Wabco ABS troubleshooting manual:
hike
—realizing each day
847
Texas Hill Country
Ours does not come on when changing CTIS modes. Though we have seen ABS lit while off roading in SAND. I read this reference you shared to be normal though caused by "road conditions" not CTIS mode setting. Also it is referring you to the "off-road ABS information" nearby in the manual.
You may also want to check your fault codes—
aw113sgte
975
La Crosse, WI
There are no fault codes(checked with wabco abs software )I can literally stop that light blinking by switching to highway mode, the second I go to any of the other modes the light starts blinking again.
I did verify ABS functions perfectly in highway mode, then in any of the other modes maybe I just turned off and it lets the wheels skid.
This is the module I now have https://www.ebay.com/itm/2045669784...REya4EHS9C&var=&widget_ver=artemis&media=COPY
hike
—realizing each day
847
Texas Hill Country
The link shows that listing sold in December and provides no information about what was sold.
Here is our unit:
The pin out of the M939A2 model is different than the pin out of the M1078A1 model and caused a fault in our J1939 diagnostic wiring path which burned up R12 and R13 resistors. We pulled the 'G', 'W', and 'X' pins off our CTIS controller to clear the wiring conflict, (pictured before pulling the pins). J1708 diagnostics is what our Dana Spicer software uses.
