- 217
- 778
- 93
- Chesapeake, VA
Good call on the o-rings, I completely forgot about those on mine and will have to get a set too. Are either of these the right ones?I was able to get the majority of the front axle reassembled today with the exception of getting the hubs back on. Should have her buttoned up tomorrow. Had to replace one inner bearing cup and one stub shaft needle bearing. Then, the spindle seals were replaced as well and I’ll need new o-rings for the lockouts as well but I’ve yet to source those. I’ll be temporarily reusing the old o-rings to keep any moisture out though.
Not quite sure yet.Good call on the o-rings, I completely forgot about those on mine and will have to get a set too. Are either of these the right ones?
QU56016 Warn® Dana 50 and Dana 60 Hub O-Ring
Buy Now QU56016 Warn® Dana 50 and Dana 60 Hub O-Ring fits between the wheel hub and chrome outer cap of Warn® plastic dial lockout hubs.torqueking.com
QU40152 Hub Dial O-Ring for Spicer Dana 60 Locking Hubs
QU40152 New Spicer Dana 60 Hub Dial O-Ring for 1977-1981 Chevy or GMC and 1978-1979 Ford is a current production replacement Hub Dial O-Ring for Spicer Dana 60 Spline Mount, Plastic Dial Locking Hubstorqueking.com
.Clean and paint, clean and paint.
Wow those look great! I’m going to be using a flat black as well. Should get the final coat on tomorrow if the weather holds out.Yes I restored my springs the same way. You will not regret the extra work. Several people call me crazy, and that's Ok, because I AM CRAZY.
View attachment 860632 View attachment 860633
.Been there... Sprayed with EZ-Slide after painting and installed new friction pads.
I read about it while looking up some info on rebuilding springs. It has worked well and I think the truck rides better than it did stock. My local Tractor Supply had it in stock..
That is neat! I had no idea there was any such thing.
Paint with built in "slickem" is pretty awesome.
Great I’ll look into it thanks for the tip!I read about it while looking up some info on rebuilding springs. It has worked well and I think the truck rides better than it did stock. My local Tractor Supply had it in stock.
